clutch noise!
Discussion in 'Technical Chat' started by stunt man hans, Jul 11, 2011.
  1. Jul 11, 2011 at 10:32 AM
    stunt man hans
    stunt man hans [OP] DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    when the truck has been driven a bit and comes to operating temp its now making this noise when my foot is off the clutch but when i push it all the way in the clutch stops making noise.
    its something in there making a clattering noise at first i thought it was the ac unit but, i realized the other night it was in fact my clutch. so to recap foot off the clutch clattering noise foot depressing the clutch no noise wtf its a brand new truck that i never take above 3,000 rpm?
  2. Jul 11, 2011 at 5:27 PM
    Coreyjon
    Coreyjon Northern Alliance: Airlift Div
    Upstate, Ny
    08 DCab 4X4 SR5 TRD Sport
    iPod Adapter, Bilstein 5100's @ 1.75" front, Wheelers 3-leaf 1.5" + overload rear (2"), custom carrier bearing drop spacers.
    The throw out bearing could cause that.
  3. Jul 12, 2011 at 5:10 PM
    Kawi kilburn
    Kawi kilburn Member
    Moore, OK
    '05 SR5 4x4
    Condor motorcycle chock
    I noticed the same issue on mine over the last few months.
    Subscribed
  4. Jul 12, 2011 at 7:41 PM
    jassco
    jassco Well-Known Member
    Boston
    2010 Access Cab 2.7L SR5 5spd, 4x4
    5100 set to .85 w/ rear TSB, 2012 Rear-view Mirror, Grillecraft, Team Trails FJ Wheels, TPMS canister, Rear headrest delete, Rear console delete, Valley Hitch, Frame undercoat, $2.99 Tailgate hose clamp lock, Avid light bar, 4x4 lighted switch ala Biceman.
    OP is 4 cyl - TSB is for 6 speed V6 only. Search for "diesel sound". It has something to do with the AC putting more load on idle engine. No one has officially acknowledged it yet though.
  5. Jul 12, 2011 at 10:50 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    yes it absolutely has something to do with the ac. when the compressor kicks on and your foot is off the clutch it clatters and sounds horrible but, if you press the clutch in the noise stops clutch out chattering again.
    the air blows ice all day but sounds fucking horrible its to the point now where it has been to toyota of turnersville twice for this noise and the acfan squeaking they can't seem to reproduce the problem at all. the next time it happens i'm driving there no matter what so they can get a listen to it.
    if it is the throw out bearing what does that entail do they have to take the trans apart to get to it? i have to say i'm not thrilled t the idea of them taking my new truck apart for a problem that has been affecting many tacomas. same thing can be said for the climate control fan. i guess i'm just not understanding why there have been no ends to these problems. seems a little extra gay to me.
  6. Jul 12, 2011 at 10:56 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    it started in the winter time so maybe having the ac on just exacerbates the noise because i can remember hearing it in the colder months as well when i know i did not have the ac on. i'm running the 4cyl 5 speed manual trans psu so idk if the tsb will count for mine but, it sure sounds like a rattle and it does it when the clutch is out and stops when i depress it so it must be the same issue.
  7. Jul 13, 2011 at 6:03 AM
    jassco
    Boston
    A/C seems to exacerbate noise because of the additional load on engine.
    This has been going on for a few years now still no fix here:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/49243-rattling-type-noise-diesel-sound.html
    Not taking the trans apart piece by piece, but getting to the TOB requires this -
    http://www.youtube.com/watch?v=UHNNDdxYeT8
  8. Jul 18, 2011 at 2:00 PM
    rdp5008
    rdp5008 Well-Known Member
    Russell
    Missouri
    2001 Tundra
    ARE Camper Shell
    Add me to this list. It sounds like my clutch is eating itself and shifts like crap. Under 10k miles here.
  9. Jul 30, 2012 at 5:59 PM
    CajunTacoma
    CajunTacoma Member
    Pensacola
    '10 PreRunner SR5
    tinted windows. lift,tires and wheels soon!
    4cyl 5 speed here. had the throw out bearing replaced around 20,000 miles and it is back again at 50k. i also have a terrible squeak/creak coming from what im guessing is the slave cylinder? the piece on the side of the gearbox with the rubber boot on it and a bleeder valve is what im trying to describe... if i mess with the cycliner by hand i can get the noise to go away and every now and then while driving around town i notice the noise going away... no experience with standard transmissions here
    it's a terrible noise!
  10. Jul 31, 2012 at 7:14 AM
    jassco
    Boston
    The point where the slave boot meets at a metal tip point contacts the shift fork. This is where the majority of the noise happens. You need to get some lubrication in there.
    The lazy way is to spray lithium grease there every time. This won't last long but doesn't require much effort. The proper way is to unbolt the slave and use heavy bearing grease on the tip and fork contact. This should last longer. It sucks, but this is how it was designed.
  11. Jun 20, 2015 at 6:32 PM
    DMagoo147
    DMagoo147 Well-Known Member
    Dan
    MA
    08 TRD OffRoad A/C
    CBI off road fab sliders with kickout, K&N performance air filter, BriteAssLED headlight bulbs, Delta Pro tool box, 20% window tints in front, 20% window tints added onto rear windows. Lou's Custom Exhaust: SS pipes and dual tip. LED backup lights. Prevent tailgate theft mod. Plastidip stock wheels, lower valence rear bumper and grill. bedside bottle opener. RAM-X phone mount. GTA car kits iphone/aux adapter.
    Gents, has anybody found a solution to this? It has been 3 years since the last post
  12. Jun 20, 2015 at 6:46 PM
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    WeatherTechs, Console Vault, OEM Bed Mat, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, Exterior Cargo Net, OEM Toyota Cargo Divider, Cobra CDR 840 Dash Cam, Sliding Rear Window Security Bar, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Full Debadge except TRD OEM Red Tailgate Badge, Undercover SE Tonneau
