Clutch Noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by TRVLR500, Apr 21, 2018.
  1. Apr 21, 2018 at 9:20 PM
    TRVLR500
    TRVLR500 [OP] Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I noticed about 6 months ago that when my truck is sitting there idling there is a whirring sound. It's obviously the clutch. When I depress the clutch pedal the noise stops about half way down. I've checked the adjustment and there is about 1-2" of play before the clutch engages so I don't think the TOB is making noise because the clutch is out of adjustment.
    It's not a bad noise and it is not a grinding noise. It's not very loud either. It's just there. What do I have to worry about? The truck is a 2004 RC Tacoma with the 2.7 and 4X4. Am I looking at a TOB replacement in the future and how long have I got?
    Mike likes Tacos likes this.
  2. Apr 22, 2018 at 6:34 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    I think it's the transmission, not the clutch. In neutral with the clutch pedal out parts of the transmission still spin and make a noise. Pressing on the clutch makes the spinning stop, so the noise stops. Perfectly fine.
    cruxofthebisquit likes this.
  3. Apr 22, 2018 at 7:02 AM
    Kansas TRD Taco
    Kansas TRD Taco Active Member
    Aaron
    Littleton, NH
    2002 Toyota Tacoma 4X4, V6, TRD, Ext Cab, 5 speed manual
    Agreed. Most likely the transmissions input shaft bearing making some noise. The Aisin R series transmissions are know to make some noise, even when new.
  4. Apr 22, 2018 at 6:23 PM
    TRVLR500
    Wyoming
    Thanks, that's good news. I won't worry about it then.
  5. Apr 23, 2018 at 9:02 AM
    Trapperpete52
    Trapperpete52 Well-Known Member
    Pete
    98 Tacoma 4 X 4 5 speed 93 Tacoma 4 X 4 5 speed 95 Tacoma 4 X 4 5 speed
    roll bar and lights
    I would at the least check the fluid level in the transmission and transfer case just to be sure.
  6. Apr 23, 2018 at 9:06 AM
    Mike likes Tacos
    Mike likes Tacos Mod in Training
    Northridge,CA
    2014 4x4 DCSB
    Long travel with big tires and lights
    Sounds like throw out bearing. If your under warranty and can get the noise to do it at the dealership they should replace it. Good time to consider buying a new clutch if you need it cause they gotta drop the tranny to do the job anyways.
    wilcam47 likes this.
  7. Apr 23, 2018 at 9:30 AM
    mwrohde
    Sugar Hill, GA
    It's a 2004. It's probably out of warranty.
    Kiloyard likes this.
  8. Apr 23, 2018 at 9:40 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    I have a 98 with the 5 speed, V6. I had the R150 completely rebuilt. new Bearing and synchros. Also a new input shaft, TOB as well. Ne flywheel and Marlin Crawler Clutch kit.
    Makes that same exact noise. I will be sitting there in the bank drive-thu and when in neutral it makes that noise. Depress clutch and it goes away. Even took it back to the verteran transmission shop guy who did all the work. Said "it must be gear wine". lol It's not getting worse or causing any issues. I just think these things are noisy IMO.
  9. Apr 23, 2018 at 9:43 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I'm not sure about a whirring noise but I have the dreaded TOB chirp and it sounds like a 100 angry chirping crickets when I'm idling or coasting, as soon as I press the clutch or accelerate it goes away. I've dealt with it on 2 clutches now, it's just one of those annoying Toyota manual transmission quirks I guess.
  10. Apr 23, 2018 at 2:52 PM
    Kansas TRD Taco
    Aaron
    Littleton, NH
    Same thing here. Installed a rebuilt Marlin R150F this spring. Made the noise with the old transmission, makes the noise with the new/rebuilt unit.
  11. Apr 23, 2018 at 3:07 PM
    Xbeaus
    Beau
    So that means it's normal! lol I've taken numerous road trips and nothing bad has happened. Just makes all those old pickup noises I guess!
  12. Apr 23, 2018 at 7:13 PM
    TRVLR500
    Wyoming
    Yeah, my noise is "just there". No chirping, no grinding. You can just hear something spinning and it's not loud at all. Based on all the posts it seems to be normal. I won't worry about it unless something stops working or I hear grinding or something really weird.
  13. Apr 23, 2018 at 7:15 PM
    TRVLR500
    Wyoming
    That would be a good guess since it's 14 years old.
  14. Apr 23, 2018 at 7:16 PM
    TRVLR500
    Wyoming
    That's a good idea. I'll do that this weekend just to make sure.
  15. Apr 23, 2018 at 9:07 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Have you guys adjusted the clutch pedal for proper free play? I remedied this issue by doing so.
  16. Apr 24, 2018 at 7:49 PM
    TRVLR500
    Wyoming
    I checked mine because I know the free-play is important. I've got plenty. About an inch or 2.
