Clutch not disengaging...hard to shift
Discussion in '1st Gen. Tacomas (1995-2004)' started by dannycrocket, Apr 6, 2015.
  1. Apr 6, 2015 at 8:22 PM
    dannycrocket
    dannycrocket [OP] Member
    Mac
    Gunnison, CO
    2001 Tacoma 4x4 STD CAB
    I have a 2001 Tacoma STD cab 4x4 2.7L. The clutch doesn't slip but it shifts hard or I can't get it in gear a lot of times at a stand still. I've noticed this evening, that the clutch isn't totally disengaging and is dragging the truck slightly along when clutch is fully depressed. The reservoir is full and I bled the slave cylinder last fall after a dog ate the flexible clutch line :) Is the master or slave cylinder bad? Or throw out bearing or clutch bad? Clutch chattering has gotten worse since I bought it last year. Truck has 125K miles on it, no idea if clutch has been replaced.
  2. Apr 7, 2015 at 6:10 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    I'm sure GearCruncher will be along soon, and he knows way more about this than I do.
    How many miles were on the truck when you bought it? I'd almost bet you have the original clutch.
    There is a pedal adjustment under the pedal. You could try adjusting it and see if you can push the clutch a little further.
    One of the cylinders leaking is a possibility, as well. The slave cylinder will visibly leak if it is the culprit. The master will not. I don't know how to test the master cylinder. Both are pretty easy to replace. Don't buy cheap ones. For example, I'll never buy a brake or clutch cylinder from Autozone again. My failure rate is north of 50% with them.
    After you jack with that, it's a new clutch. But, wait for someone who knows more. It shouldn't take long.
  3. Apr 7, 2015 at 6:20 AM
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    I know a little about this, but am by no means and expert. The basics I see are this;
    If the truck is moving at all the clutch is currently operable. Generally a clutch plate will show failure while the truck is moving with a heavy load, via a "hill" or towing something.
    If the clutch is fully depressed and some separation occurs, but not full separation the master cylinder is working, but the slave is not.
    The chatter however could be signs of a failing clutch or poor re-engagment of the clutch plate when released.
    Again, I am by no means an expert!; but I have driven and worked on manual transmission cars and trucks and personally owned a 1978 Toyota Corolla that had the exact same symptoms you describe and the slave cylinder was the culprit.
  4. Mar 15, 2016 at 7:08 PM
    tacotuesday81
    tacotuesday81 darkeye
    Darcy
    beaumont, alberta, Canada
    2014 Tacoma TRD offroad
    Urd tcai. Dtlt headers maf call. Urd stage 3+ cluch lws, magnusson 2.55 pully, uconn ems
    I have the same problem. I've been driving manual transmissions my whole life. But I cooked the stock clutch with 6000 km on it. Wtf? Toyota wouldn't cover it. Now have the same problem as decribed with a stage 3+ with 16000 km on it. Have you found the problem?
  5. Jun 22, 2021 at 11:01 AM
    Toyotagang
    Toyotagang Well-Known Member
    Kainoa
    2005 black Toyota Tacoma 4cyl 4x4
    Anyone find the problem?
  6. Jun 22, 2021 at 12:33 PM
    Glamisman
    Glamisman Well-Known Member
    if the pilot bearing in the end of the crankshaft is dry it will turn the transmission input shaft with the clutch disengaged. If there is any misalignment of the transmission to the block the same thing will happen.
