Clutch options
Discussion in '1st Gen. Tacomas (1995-2004)' started by James from Oregon, Mar 28, 2017.
  1. Mar 28, 2017 at 1:57 PM
    James from Oregon
    James from Oregon [OP] Well-Known Member
    James
    1997 Tacoma
    Coil over lift up front, OME springs in the back
    Hello TW
    Ive just added some weight to my truck and am now thinking of replacing my clutch. Ive always previously gone with parts store specials, or slightly above budget options. But this time around I think that I should go with a more appropriate option given the additional weight.
    First though, I must tell you that I do not mind at all spending more to buy a better product. I also do my own labor. I also love turning wrenches and have done dozens of clutches. So the ideal clutch for me would be something that grips well under weight and high torque loads, longevity would be great but not at the expense of performance.
    I also havent been able to find any flywheel options, just the run of the mill stock weight flywheel. Are there light weight variants that are acceptable for offroad and daily use?
    Thank you for your input!
  2. Apr 15, 2017 at 2:25 PM
    Nedrolls
    Nedrolls Well-Known Member
    Scott
    Coquille, Oregon
    1999 Ext cab beater. 2016 Pro 4Runner(wife's)
    Late reply, but I believe the consensus on clutches is to go with a factory Toyota clutch
  3. Apr 15, 2017 at 6:42 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    I have LCEngineering's clutch kit:
    https://www.lceperformance.com/Dual-Comp-Clutch-Kit-5VZ-95-04-10-p/1053033.htm
    And their 38# flywheel:
    https://www.lceperformance.com/High-Torque-Flywheel-5VZ-38lb-Steel-p/1051007.htm
    I'm daily driving about 1000# over stock weight. And when I'm loaded up for camping about 1600#.
    Flywheel and clutch are great. The heavier flywheel, has made it so I've never stalled my engine lugging over the rocks. I just blip the throttle, and it just lugs me over.
    Although, I have a vibration at idle and until I replace the engine and transmission mounts I suspect my flywheel is not completely balanced.
    Marlin crawler is also a vendor where folks here like to by clutches...
    Nedrolls likes this.
  4. Apr 15, 2017 at 10:31 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    OEM or Marlin Crawler. Make sure you get an OEM throw out bearing, Marlin also sells OEM flywheels and hardware like slave and clutch cylinders, bolts, etc
  5. Apr 16, 2017 at 3:17 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Little late but I would say if I needed another Clutch I would go with Marlin Crawler
  6. Apr 16, 2017 at 6:24 PM
    Wulf
    rock raisin
    Make sure to replace the throwout bearing!! I didn't and I think I'm going to replace the clutch prematurely to deal with the squeaky TOB
  7. Apr 17, 2017 at 9:38 PM
    Laxtoy
    Maltby, WA
    Agreed, I did a factory Toyota one last time and it's been great, but I think I'll go Marlin on the next one, they seem to have put a lot of thought into that setup, a lot of people prefer them over OEM
