Clutch pedal adjustment question
Discussion in '4 Cylinder' started by TSSFiveSpeed, Nov 14, 2022.
  1. Nov 14, 2022 at 8:38 AM
    TSSFiveSpeed
    TSSFiveSpeed [OP] Well-Known Member
    Damion
    ar kansas
    5 speed taco pimped out
    Cold Air Intake, Shift Knob, Radio, URD Short Throw Shifter Kit, Pioneer 6 1/2 speakers, sound deadened, LED headlights, LED tails, 4 inch lowering blocks, bilstein rear shocks, Cooper A/Ts, oil catch can
    I recently changed my clutch in my 2005 Tacoma, has the 5 speed, and it made the bite point on the clutch pedal really high, almost complelty taking my foot off the pedal, i tried to adjust it but never figured out how, how would i do it
  2. Nov 14, 2022 at 8:42 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    There is a locking nut, take that loose, and adjust the length of the push rod on the clutch master cylinder near the pedal. The link below has a FSM picture in the first post. There should be 5mm-15mm of free play in the pedal before it starts engaging the master cylinder push rod
    https://www.tacomaworld.com/threads/clutch-height-adjustment.610495/
  3. Aug 23, 2024 at 10:05 AM
    Crippler25
    Crippler25 Well-Known Member
    It takes a little while to get the air out
