Clutch pedal adjustment rod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SAS5ZFEMIKEY, Jun 18, 2021.
  1. Jun 18, 2021 at 7:31 PM
    SAS5ZFEMIKEY
    SAS5ZFEMIKEY [OP] Member
    91 SAS 5vzfe Pickup
    Hi all, just did a clutch/flywheel job on my gfs truck, got new parts in and pressure, however the clutch lets out very high (at almost full return to resting position).
    ive been trying to mess around with the adjustment rod, loosened the 12mm lock nut and held the 14mm with wrench while trying to spin the rod but it’s so stiff! I can’t turn by hand and I might get a 1/16th of a turn with vice grips. Any suggestions would be greatly appreciated thanks!
  2. Jun 18, 2021 at 8:04 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    All I got is this:
  3. Jun 18, 2021 at 8:05 PM
    Jason J
    Jason J Well-Known Member
    oregon
    08 tacoma 4x4
    It sounds like it already has preload on it or bad corrosion. Loosen the jam nut a bunch and thread the rod further into the 14mm side of plunger which will be loosening it up. After it's loosened up it should spin freely with finger tips. You can generally spin it until you hit resistance and tighten the jam nut and you'll be close in adjustment.
