Clutch pedal and master cylinder replaced
Discussion in '2nd Gen. Tacomas (2005-2015)' started by silverbullet2011, Mar 27, 2013.
  1. Mar 27, 2013 at 11:43 AM
    silverbullet2011
    silverbullet2011 [OP] New Member
    Marcus
    Charlotte, NC
    2011 4x4 6sp manual SR5
    I have a 2011 Tacoma access cab 4x4 4.0L 6spd manual transmission and factory tow package. The clutch pedal creaked when engaged from the day I bought it. I looked for TSB's but couldn't find one for my model year. I finally got the dealer to fix the problem yesterday under warranty. They replaced the clutch pedal and the master cylinder assembly. When I drove it home today, the clutch felt weak. When I took my foot off the clutch, it stopped moving at a lower point than my old clutch did. I'm concerned that the dealer put in a clutch pedal or master cylinder assembly that was not intended to be used on a truck with my set up. Does anyone know if a truck with a tow package requires different parts than one without? If so, how can I tell if they installed the correct parts?
    I'm not sure if they fixed the problem yet, as the old one creaked when it was hot outside (and consequently inside the truck). Even then, when the AC cooled the truck (really cool), the creaking was reduced.
  2. Mar 27, 2013 at 12:01 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Im fairly certain clutch pedal assemblies are the same fro the 6 speeds. Check the part number on the invoice and check that it matches tacoma clutch part numbers. There is a TSB for the creaky clutch pedal. I just had mine done on my 2011 6 speed a few months ago.
  3. Mar 27, 2013 at 12:06 PM
    silverbullet2011
    Marcus
    Charlotte, NC
    Thanks for the info. I'll check into the part #. Did your clutch feel different after the fix?
  4. Mar 27, 2013 at 12:09 PM
    moondeath
    Pa, Gardners
    It felt smoother because it didn't creak anymore, but not really different. TSB # for new clutch pedal assembly is TSB 0186-12.
    Parts:
    Cylinder Assembly Master Part# 3142004020
    Pedal, Clutch Part# 3131104012
    Brake Fluid
  5. Mar 27, 2013 at 12:42 PM
    silverbullet2011
    Marcus
    Charlotte, NC
    Thanks. My part #'s match the ones you posted. However, TSB 0186-12 lists these 3 parts that need to be replaced: the clutch release cylinder, clutch release fork support and clutch release bearing. The 3 parts replaced on my truck were not these parts. (After closer inspection of my invoice, I noticed that the clutch pedal sub assembly was replaced as well.)
  6. Mar 27, 2013 at 6:43 PM
    cheech1
    cheech1 Well-Known Member
    Kaneohe, HI
    08 PreRunner Off Road
    Maybe the different clutch feel you describe is due to improper bleeding of the system. Take it back.
  7. Mar 27, 2013 at 7:29 PM
    moondeath
    Pa, Gardners
    Weird that you had the same TSB number. What your talking about, I think, is a different issue with a creaky release bearing. There was a TSB for that also, which is different from the clutch pedal creak. That's what I had replaced. You had the bearing and assemblies replaced.
  8. Mar 28, 2013 at 3:27 AM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    I had this exact same experience.
    Clutch was creaky. Had it lubed at 16,000km, then replaced at 32,000km. It felt like there was a dead spot at the top of it, as if there wasn't enough fluid in the system. I ended up not having it looked at after that, but I drove across the country with it, and now just rolled over 48,000km and have had zero issues with it. It is just now starting to creak again.
  9. Apr 13, 2013 at 3:29 AM
    tacoma steve
    tacoma steve Well-Known Member
    NH
    2012 TX Baja
    Brought my truck to dealer yesterday for the clutch pedal squeaking although mine does it when it's colder out and goes away when it warms up. But they are replacing clutch pedal assembly and clutch master cylinder when the parts arrive. hopefully will be able to get it done next friday.
  10. Jun 12, 2014 at 2:14 AM
    tacomarich
    tacomarich luvsoffroading
    rich
    arizona
    trd 4x4 offroad
    my clutch squeaks cranks but only after parked in the heat for 4 plus hours. I want the dealer to do it but they require me to leave the vehicle all day because they couldn'reproduce the issue but they only had it in the heat for 2& half hours how did you guys go about getting the dealer to do this?
  11. Jun 12, 2014 at 3:02 AM
    tacoma steve
    NH
    2012 TX Baja
    Mine was squeaking when I brought the truck in.
  12. Jun 12, 2014 at 4:44 AM
    gearcruncher
    Canadain bumper technician
    When the technician installs a new clutch pedal , chances are he is adjusting the free play at the top of pedal by the book . This usually means there is going to be about half an inch of free play at the top of pedal . As the clutch wears down the free play goes away .. Our trucks do not have a self adjusting clutch so we need that free play at the top of the pedal to keep your throw out bearing from turning all the time .
  13. Jun 13, 2014 at 2:19 AM
    tacomarich
    rich
    arizona
    trd 4x4 offroad
    does anyone have a pdf or link for the updated tsb 0186-12 for this clutch noise issue?
  14. Nov 14, 2014 at 12:20 PM
    tacoma steve
    NH
    2012 TX Baja
    Had to go back to dealer today for squeaky clutch pedal. They need to replace everything again. 1st time was at 8k miles now I'm at 27k
  15. Nov 14, 2014 at 12:28 PM
    Findus11
    Findus11 Well-Known Member
    Durango
    07 Taco
    yup same experience. Had the TSB done, clutch felt like a soft turd. Drive it for a couple of days, mine got better and feels like stock again after driving around a bit. But now it squeaks again, I think Toyota just made that a feature free of charge in our trucks
  16. Nov 14, 2014 at 12:30 PM
    tacoma steve
    NH
    2012 TX Baja
    I have to wait til they order the parts so its not even done yet. I'm going to make sure that if it happens again it better be free cause I'm certainty not paying for something they couldn't fix for free. Once it's out of warrenty
  17. Nov 29, 2014 at 4:39 PM
    tacoma steve
    NH
    2012 TX Baja
    So talked to dealer toyota will not replace the parts again so they want me to bring the truck in so they can grease some things. See if this works.
