clutch pedal bushing - master cylinder nuts?
Discussion in '1st Gen. Tacomas (1995-2004)' started by htuong95, Oct 23, 2010.
  1. Oct 23, 2010 at 10:23 PM
    htuong95
    htuong95 [OP] Have a nice day
    Sacramento
    2001 Tacoma 4x4
    Full OME suspension, Level 8 Tracker 16" wheels, BFG T/A KO 285/75/16, etc., work in progress...
    I am getting ready to replace my clutch pedal bushing. I have all the stuff needed. I just have one question. Why do I need to remove the master cylinder nuts? Here are some links to instructions on how to replace the bushing - http://www.4runners.org/writeups/clutchbush/index.html http://www.customtacos.com/tech/index.php?article=166 http://www.lieblweb.com/clutchbushing.html . All of them tells you to remove the master cylinder nuts. The clutch pedal is well below it. I am missing something here?
  2. Oct 24, 2010 at 7:11 PM
    richj777
    richj777 New Member
    Rich
    Denver
    04 4WD SR5 V6
    TRD supercharger, Flowmaster, more
    It tells you why in #3 of the second write up. These are removed to remove the entire clutch pedal assembly from under the dash so that you can easily remove the spring on a bench.
    There are 3 bolts total, 2 on the engine side of the firewall at the master cylinder, and one inside. Pull the clip and the pin, then the whole thing comes out. The pedal itself is lower than the cylinder, yes. But where the whole thing attaches is up at the master cylinder. Easy repair, and so worth the time. I did all three bushings.
