Clutch Pedal Creaking - how fast does it progress?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by whitebread, May 21, 2020.
  1. May 21, 2020 at 10:13 AM
    whitebread
    whitebread [OP] Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    My clutch is making a creaking/groaning sound when it’s cold out. The dealer couldn’t recreate it (I showed them this video, but that isn’t sufficient proof). I know there is a tsb for this and my truck has 15k miles on it.
    Since the dealer can’t recreate it, my question is, will this creak get progressively worse? Hopefully to the point where they can’t deny it’s going on?
    It started about two days ago.
  2. May 21, 2020 at 10:18 AM
    crunchytaco13
    crunchytaco13 Well-Known Member
    ‘17 PRO MT Cement
    TRD CAT
    Can you provide the TSB on this? is this for your ‘19?
  3. May 21, 2020 at 10:20 AM
    whitebread
    Raleigh, NC
    2019 OR 4x4 6MT
  4. May 21, 2020 at 10:20 AM
    Shellshock
    Iowa
  5. May 21, 2020 at 10:22 AM
    Shellshock
    Iowa
    honestly it’s not worth bothering with the TSB. People have had it done and it comes back after a while.
  6. May 21, 2020 at 10:23 AM
    crunchytaco13
    ‘17 PRO MT Cement
    TRD CAT
    I’ve got 20k on my ‘17 and have the same intermittent sqeak. Never done anything about it, but would honestly rather grease it myself then deal with someone replacing parts - less headache and risk in something else worsening.
    Junkhead likes this.
  7. May 21, 2020 at 10:24 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The only thing there is that the latest TSB is supposed to have improved parts. Some folks got it done in another thread. It is probably too early to judge the success of it.
  8. May 21, 2020 at 10:24 AM
    Malibu7tss
    Malibu7tss Can' t think of anything to type here right now.
    Central pa.
    2016 trd sport dcsb 4x4 bbp 6spd manual
    Old man emu with 888's and headstrong off road progressive aal, trd pro wheel, Cooper Stt Pros 285/70r17
    I have had the pedal and related parts replaced multiple times and the noise always comes back. There are instructions on this site somewhere that show where to lube and what to use to fix it. The tsb doesn't fix it. At least in my experience it doesn't
    shakerhood, Shellshock and tonered like this.
  9. May 21, 2020 at 10:25 AM
    crunchytaco13
    ‘17 PRO MT Cement
    TRD CAT
    Anyone else who has seen this thread, can you paste URL to some simple instructions on this? I need to follow suit
  10. May 21, 2020 at 10:28 AM
    Shellshock
    Iowa
    it’s been a problem forever though. Grease is the easy fix, just becomes another maintenance item
    I think the only real fix is throwing it all in the trash like @St.Germain and swapping for non plastic parts
    su.b.rat and tonered[QUOTED] like this.
  11. May 21, 2020 at 10:31 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Very true. I did the grease thing at the beginning of winter and life has been good.
    Shellshock[QUOTED] likes this.
  12. May 21, 2020 at 10:34 AM
    Shellshock
    Iowa
  13. May 21, 2020 at 10:35 AM
    su.b.rat
    su.b.rat broken truck
    yes it's been a 100% success over here. as solid as i could hope for.
    no big bells & whistles to report. all i can report is: wow this whole clutch setup is so totally normal and right that i don't even notice it. the OE bit never ever stopped grabbing my attention and that sucked. all i wanted to do was drive. now it's a dream.
    Tony i think you could do that parts swap with handtools in an afternoon for under $200.
  14. May 21, 2020 at 10:35 AM
    Shellshock
    Iowa
    Using a good high temp grease definitely helps it last longer
    tonered[QUOTED] likes this.
  15. May 21, 2020 at 10:36 AM
    Shellshock
    Iowa
    This may be my next project. I’m running out of other things to do lol
    su.b.rat[QUOTED] likes this.
  16. May 21, 2020 at 10:38 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    I will have to give this a try. Typical dealership scenario for me where they cannot recreate it but it still does it the moment I drive away.
    Winch likes this.
  17. May 21, 2020 at 10:39 AM
    Malibu7tss
    Central pa.
  18. May 21, 2020 at 10:45 AM
    phoryu2nv
    phoryu2nv Well-Known Member
    '19 Cement TRD Sport 4x4 DCSB 6spd
    I had the same problem with my '19 with less than 5000 miles on it. Dealer did the TSB no questions asked, hasn't come back since and hope it doesn't.
    Junkhead and tonered like this.
  19. May 21, 2020 at 10:45 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yep. I got some thick disk brake grease. Good stuff.
  20. May 21, 2020 at 10:49 AM
    squarenone
    squarenone Well-Known Member
    SoCal
    2018 TRD OR 4x4 6sp-mt
    Guess I'm lucky, my squeak went away after a couple hundred miles and I never bothered to lube it.
