Clutch Pedal is leaking.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma63, Oct 10, 2011.
  1. Oct 10, 2011 at 7:35 PM
    Tacoma63
    Tacoma63 [OP] Member
    07 Crew Cab 4x4
    I have a 2006 tacoma 5 speed, 4 cylinder. And my clutch pedal is saturated, not leaking a whole lot but enough to make me concern. I've talked to different mechanics and they say its a bushing in the housing or I have to change out the whole clutch pedal, they also said its the master clutch cylinder. If anyone has input let me know. Thnx for yalls time.
  2. Oct 10, 2011 at 7:37 PM
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    Happened to me last week! does the clutch stick to the floor? They ended up replacing my slave and master cylinder it cost me 184.xx Good luck OP!
  3. Oct 10, 2011 at 7:40 PM
    Tacoma63
    07 Crew Cab 4x4
    No it doesn't stick to the floor. But Squeaks when letting clutch out slowly also who did the replacement for you, was it dealership or outside of dealer? and if so was it under warranty?
  4. Oct 10, 2011 at 7:49 PM
    07TaCo07
    07TaCo07 Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    What he said
  5. Oct 10, 2011 at 7:57 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Sounds like a bad master cyl.
  6. Oct 10, 2011 at 8:15 PM
    saugus
    saugus Well-Known Member
    The squeaky clutch pedal is a routine issue. I didn't even notice it on mine until I pulled the dealer history. The original owner made a lot of hay over it. I can see the new pedal sticker on my pedal from when it was replaced. It squeaks. So what, it's a truck. BTW, good luck with that. Let us know the outcome.
    On a side note: I find it bizarre that the only one of the three pedals that is not metal is the clutch. Plastic.:mad:
