Clutch pedal noise???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cllowe24, Aug 25, 2016.
  1. Aug 25, 2016 at 5:43 PM
    cllowe24
    cllowe24 [OP] Well-Known Member
    Mid Tennessee
    2015 access cab
    Billstines with 885 coils 2”aal Lce header, pro dry drop in filter, charcoal filter removal, light bar in grill, ditch lights, yaesu dual band radio, and a bunch of other junk
    so my clutch pedal on my 15 is starting to become annoying. It creeks when let out and loud. Anyone else have this?
  2. Aug 25, 2016 at 5:46 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    10trdtaco likes this.
  3. Aug 25, 2016 at 5:47 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    This was very common on the manuals. My 2011 6 speed that I had did this. One of the reasons I sold it and got the auto. There are a few things you can try to stop the noise. I had the dealer work on mine, but it wiuld always come back.
  4. Aug 25, 2016 at 5:58 PM
    eon_blue
    Azusa, CA
    My clutch pedal creaked like an old barn door, I sprayed a bit of Tri Flow lubricant on the spring behind the pedal and its been silent ever since. Almost 8k miles
  5. Aug 25, 2016 at 6:01 PM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    my 2016 creeks real bad. Can confirm it's a toyota thing and they have probably been using the same clutch pedal since 2005 with no fucks given.
  6. Aug 25, 2016 at 6:03 PM
    moondeath
    Pa, Gardners
    Thays terrible that it contiues into the next gen.
  7. Aug 25, 2016 at 6:58 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I used Disc Brake Grease on all the pivot points and its been silent ever since.
  8. Aug 25, 2016 at 9:47 PM
    lost
    lost Member
    Josh
    Flagstaff
    ASU Stickers
    I have 2014 and it was squeaking so loud. The dealer replaced the bushings and it's been ok since.
  9. Aug 25, 2016 at 9:49 PM
    shakerhood
    Southern Ohio
    Mine really made the worst noise on the Hottest Days, that's why I chose Disc Brake Grease figuring it could withstand heat better.
    cfayne likes this.
  10. Aug 26, 2016 at 6:02 AM
    ninja89
    ninja89 HUH?
  11. Aug 28, 2016 at 7:43 AM
    Doda
    Doda New Member
    (2015) On my third trip to dealer they repalced whole assembly 2 months later in hot temp it is starting to come back dealer tells me as long as warranty is good they will fix after that it's on me. So in a few more years when warranty runs out I hope there is a better fix
  12. Aug 28, 2016 at 7:51 AM
    moondeath
    Pa, Gardners
    This problem has been around for over 6 years, if not longer. Your best bet is to look into some threads where people fixed it on their own.
  13. Aug 28, 2016 at 8:21 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    This problem has been around since 2005. What does that have to do with op using his warranty for a free fix?
  14. Aug 28, 2016 at 8:50 AM
    moondeath
    Pa, Gardners
    I was responding to a different persons comment. Notice the quote in my post.
    Secondly, the fixes that have been done by other members are real fixes, not toyotas faulty replacement.
  15. Aug 28, 2016 at 8:50 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I have a jar of never seize that has a brush attached to the lid. I used that to lube the pivot point between the piston rod and pedal. Noise has been gone since beginning of the summer. I did have the assy replaced via the TSB and the noise came back. I'll stick with a bit of lube when the noise returns.
  16. Aug 28, 2016 at 9:07 AM
    cfayne
    cfayne Well-Known Member
    Santa Clarita
    2012 Tacoma V6 six speed FUN
    Pro Comp wheels General Grabber AT tires
    That is brilliant! Has the annoying squeak stayed away?
  17. Aug 28, 2016 at 9:27 AM
    shakerhood
    Southern Ohio
    Yes it has and even on the hottest days
  18. Aug 28, 2016 at 10:43 AM
    Doda
    Doda New Member
    Warranties are not free they are figured in on the cost of the truck plus I have purchased the extended warranty. Since I already paid to have the dealer fix it they will fix it. Every summer if need be. After that I will try the never seize. That would last longer than grease for this application.
  19. Aug 28, 2016 at 10:52 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    My 98 Tacoma did this, the noise was coming from the return spring on the clutch pedal inside the truck. My fix was a little grease on all areas where that spring attached. Worked good, but I did have to redo it a few yrs later.
