Clutch Pedal Not Working
Discussion in '1st Gen. Tacomas (1995-2004)' started by kevinwf, Aug 17, 2025.
  1. Aug 17, 2025 at 9:25 AM
    kevinwf
    kevinwf [OP] Member
    Kevin
    1999 Tacoma XtraCab 3.4L TRD
    I have a '99 Tacoma Ext Cab TRD. Every now and then when getting in the truck after it sits overnight the clutch pedal will go to the ground with no resistance when I press it and won't return when I release.
    If I pull the pedal back out with my foot and then re-press a few times that fixes the issue and I'm good to go.
    When it's working, the truck drives great and the clutch shifts well. No issues there.
    What might the issue be? A problem with the linkages? A bigger issue with my clutch in general? How should I diagnose this issue?
  2. Aug 17, 2025 at 9:39 AM
    jpg366
    jpg366 Well-Known Member
    AL
    09 Silver Prerunner SR5
    Hitch, Running Boards
    Is there a return spring? Symptoms sound like a master cylinder leak down.
    Bahamayellow and ControlCar like this.
  3. Aug 17, 2025 at 11:16 AM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Yeah clutch MC
    all about heat
    When Cold, the seals inside c MC are small
    Creating the floppy pedal
    one taco at operating temperature, same seals swell up lil bit…..making c MC perform properly
  4. Aug 17, 2025 at 11:37 AM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    Yeah, clutch cylinders (you have a master and a slave). Mine did this before total failure. I was able to use it for a while like that, but once it failed, it totally failed - was not driveable. If it had not failed in my driveway, it would have been a tow. Not knowing which one was bad, I just replaced them both. Problem solved. Not a tough job if you're handy.
    ControlCar likes this.
  5. Aug 17, 2025 at 12:00 PM
    kevinwf
    kevinwf [OP] Member
    Kevin
    There appears to be firm spring that is part of the linkage connected to the pedal. It was working to return the order last time I took at a look at it. Maybe it just needs some grease?
  6. Aug 17, 2025 at 12:00 PM
    kevinwf
    kevinwf [OP] Member
    Kevin
    Seems like replacing the cylinders is the way to go then.
