Clutch pedal problem.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kyle2017, May 20, 2017.
  1. May 20, 2017 at 8:25 PM
    Kyle2017
    Kyle2017 [OP] Red burrito
    2005 toyota xrunner
    2005 taco xrunner clutch wont engage or disengage.
  2. May 20, 2017 at 8:27 PM
    eon_blue
    Azusa, CA
    Stock clutch from 2005? How many miles? Probably time for a new one
  3. May 20, 2017 at 8:30 PM
    Kyle2017
    2005 toyota xrunner
    No replaced last year all new clutch pressure plate throw out bearing just replaced clutch master and slave clyinder put it in any gear just sets there trys to pull but no go.
  4. May 20, 2017 at 8:31 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    You can shift into different gears, but it doesn't move?
  5. May 20, 2017 at 8:33 PM
    Kyle2017
    2005 toyota xrunner
    Yeah trys to can see throw out bearing pushing in on fingers of pressure plate.
  6. May 20, 2017 at 8:34 PM
    Muddinfun
    Muddinfun Well-Known Member
    Either it's engaged and won't disengage, or it's disengaged(slipping) and won't engage. It's impossible to be both. Explain exactly what it does when you try to take off.
    Either, you push in the clutch, put it in gear, let out the clutch and it doesn't move, OR, you push in the clutch, and try to put it in gear and it just grinds and won't go into gear.
  7. May 20, 2017 at 8:36 PM
    Kyle2017
    2005 toyota xrunner
    Push in on clutch put in any gear trys to pull when you let out on clutch no grinding no noise of any kind except clutch pedal popping.
  8. May 20, 2017 at 8:38 PM
    Muddinfun
    Clutch is shot. Need a new one.
  9. May 20, 2017 at 8:41 PM
    Kyle2017
    2005 toyota xrunner
    Na can see it just started all at once took of one day heard a loud pop hasnt worked right since found half of clutch pedal bushing in floor.
  10. May 20, 2017 at 8:42 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Are you sure you didn't lunch your rear end?
  11. May 20, 2017 at 8:43 PM
    Kyle2017
    2005 toyota xrunner
    Positive
  12. May 20, 2017 at 8:43 PM
    Muddinfun
    That's always a possibility. Put it in gear, let the clutch out, look underneath and see if the driveshaft is spinning.
  13. May 20, 2017 at 8:45 PM
    Kyle2017
    2005 toyota xrunner
    Have put it in gear also cant push vehicle put it in neutral can push.
  14. May 20, 2017 at 8:46 PM
    FawkQ
    FawkQ Well-Known Member
    Alberta, Canada
    2013 TRD Sport DCSB V6 4.0 6M "The Sequel"
    Let's try this with grammar so it makes a little sense.
    You push in on clutch then put it in gear as per normal. Then when you let out the clutch the truck pulls ahead?
    If that is correct, then you my friend have a good clutch.
    If that is incorrect, then please try again in english what is actually happening.
    Kyle2017[QUOTED][OP] likes this.
  15. May 20, 2017 at 8:47 PM
    Kyle2017
    2005 toyota xrunner
    Yes but barely .
  16. May 20, 2017 at 8:48 PM
    Kyle2017
    2005 toyota xrunner
    I think its the pedal itself.
  17. May 20, 2017 at 8:50 PM
    Muddinfun
    The only way it could be the pedal, is if something is jammed up and won't let the clutch master cylinder release completely.
    Kyle2017[OP] likes this.
  18. May 20, 2017 at 8:52 PM
    Kyle2017
    2005 toyota xrunner
    Clutch master rod completely extends.
  19. May 20, 2017 at 8:52 PM
    Muddinfun
    If you jack up the back end, start the engine, push in the clutch, put it in gear, and then have someone break the line loose on the master cylinder, the back wheels should start spinning if it's a pedal problem.
  20. May 20, 2017 at 8:53 PM
    Muddinfun
    If the clutch is slipping with no hydraulic pressure, then the clutch has to be shot.
