Clutch pedal question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shifferbrains, Apr 13, 2010.
  1. Apr 13, 2010 at 7:40 PM
    Shifferbrains
    Shifferbrains [OP] Member
    Manteca, CA.
    06 2WD Std. Cab 2.7L
    On my '06 2wd 5speed, the clutch pedal has quite a bit of side play. It happens most when just starting to depress the pedal.
    When the pedal is at rest, there is very little side to side movement. There is also less movement when the pedal engages the clutch master cylinder.
    Is there washers, or bushings that I can replace to take up the slack?
    Thanks in advance for any help.
  2. Apr 21, 2010 at 10:35 PM
    Shifferbrains
    Manteca, CA.
    Well, I fixed the problem.
    I replaced the bushings. That was a chore getting the spring back into place.
    Also, the pedal height was too high. The clutch pedal free-play was about an inch and a half too loose.
    I adjusted the pedal height to just under 7 inches, and the pedal-free play to a smidge over half an inch. The push rod play is about 1 to 2 millimeters.
    The pedal feels so much better, very little side to side play now.
  3. Apr 21, 2010 at 11:27 PM
    btkicker
    btkicker Well-Known Member
    Denver
    '10 4x4 Reg Cab Manual
    We were a big help. :D
  4. Apr 22, 2010 at 6:25 AM
    Navigator
    Navigator Well-Known Member
    Ontario, Canada
    05 DC Sport 6spd
    17" American Racing Assaults on 265/70/17 Goodyear AT/S, TRD Exhaust, TRD CAI, Toyota Roof Rack, XM install with antenna out 3rd brake light, Red LED Map Lights, AUX Amber LED rocker switch for LED footwell lights, LUND Bug Screen, EXTANG Tri-Fold Tonneau, Hertz Component Speakers w/ TacoTunes Mounts, Infinity Kappa 4 amp, Image Dynamics 10" sub in TacoTunes enclosure, Pop n' Lock, Toyota Aluminum Wedge Running Boards, BHLM, Self Performed '05 Cowl Leak TSB, E-Z Cool Insulation/Sound Deadener applied to floorboard, headliner, and cab bulkhead, 896 Foglight bulbs as backup lights, Weathertechs, Pioneer Double Din, Scan Gauge, AutoSoft Remote Start, 2010 4Runner Heated/Signal/Puddle Mirrors.
    Like this?
    Was there a bushing kit that you can buy from Toyota. I need to do mine too.
  5. Apr 23, 2010 at 11:21 AM
    Shifferbrains
    Manteca, CA.
    Yep, the two bushings were less than $5 from Toyota. That's the easy part.
    The hard part was reinstalling the spring, many a curse word was said. But, I prevailed.
    I replaced the bushings with the whole assembly still in the truck. It would probably be much easier to replace the bushings if you removed the assembly first.
  6. Apr 23, 2010 at 11:22 AM
    Shifferbrains
    Manteca, CA.
    :D:rolleyes::D:D:cool:
