Clutch pedal rattle
Discussion in '1st Gen. Tacomas (1995-2004)' started by kincer99taco, May 2, 2010.
  1. May 2, 2010 at 8:17 PM
    kincer99taco
    kincer99taco [OP] New Member
    Saltsburg Pa
    99 Taco 4cyl 5sp 4x4
    Hello to everyone I'm a newbie here only my 2nd post, Ive done several searchs on my problem but haven't found an answer yet. I just bought a 99 4cyl 5sp 4wd reg cab and I finally found the source of my rattle under the dash, its my clutch pedal, if I stick my foot under it while goin over bumps it gets quiet so I know what it is now how do I fix it? The truck has 140,000 miles so I know there are things that are bound to be wore out but the truck is super nice and super solid so I wanna fix it right. Any help will be greatly appreciated.
  2. May 2, 2010 at 8:20 PM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    is the pedal just loose? how much play does it have before it actually engages?
  3. May 2, 2010 at 8:55 PM
    Mr.Fahrenheit
    Mr.Fahrenheit Dennis = sinneD
    American Canyon, California
    01 Taco 3.4L 5spd TRD
    K&N CAI, HUSKY LINERS, LOW PRO TOOL BOX, GRAY WIRE MOD, OPTIMA RED TOP, GOODRIDGE STEEL BRAKE LINES, FAB TECH LIFT,
    my old 99 actual mount bolts were loose, just got under there and snugged them up....clutch pedal looseness gone...
  4. Nov 23, 2019 at 7:27 AM
    Jonah.sloven
    Jonah.sloven Active Member
    Running into the same problem. Slight rattle in the pedal itself. When I use my toes on my left foot to push or rest slightly on the clutch pedal it stops, so I know its just minor play in the pedal. Any bushings or something in the assembly that could need replacing?
  5. Nov 23, 2019 at 3:00 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    4-cylinder or 6?
    Also, nice job. You resurrected a ten year old thread.
  6. Nov 23, 2019 at 3:26 PM
    Gyrkin
    Wyoming
    Well first check to make sure the moiunting bolts are all tight. After that, the v6 has a weird coil spring for the return spring. It you can get your head under there with a flash light you can see it. The plastic bushings on it wear out and the spring starts wearing a deeper knotch in the tab it sets in on the clutch pedal. When this happens it caused all kinds of problems. Could easily be causing your problem.
    Easiest fix is to replace the coil spring with a linear one. Pop that coil spring out. Just put a screw driver in-between it and the bracket and pry it loose. Then get a brake pedal return spring and put it on instead. Easy to install. There is a rod with a grove in it on the pedal one end goes on, and a tab with a small hole in it up under the dash that the other end goes in. The 4 cylinder models use a linear spring so the connection points are already there. I don't guarentee this will fix your problem, but it's easy to do and inexpensive.
    advrider269 and Jonah.sloven like this.
