Clutch pedal squeak
Discussion in '1st Gen. Tacomas (1995-2004)' started by Evasquez, Apr 14, 2009.
  1. Apr 14, 2009 at 9:41 PM
    Evasquez
    Evasquez [OP] Evasquez
    Kansas City
    2001 SR5
    265/75/16 Mickey Thompson Baja ATZ Radial (Traditional), everything else is stock
    every time i push it down and release it, the most annoying squeak sound happens...I have read a few threads but does anyone know how to fix this?
    Thanks
  2. Apr 14, 2009 at 10:06 PM
    MotoTacoma
    MotoTacoma Adrenaline Addict
    Pencilveineeya
    14 Tundra TRD OR, 05 GX470
    tacoma sold 11/13/13 GX470 has 2” Dobinsons IMS w/JBA UCA, Baja Designs S1 ditch lights, more to come!
    if it makes you feel any better, the 05+ do it too... oil/lube doesn't help it either.. if the guys are under warranty they replace the whole assembly.. i don't know if there are any fixes for your body style besides lube..
    good luck
  3. Apr 15, 2009 at 1:18 PM
    natebaur
    natebaur Active Member
    elkorn
    00 toyota tacoma single cab
    thrust berrings ma
    ybe
  4. Apr 15, 2009 at 1:41 PM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    The sound you're hearing is most likely the release bearing fork, which sits on a round pivot inside the transmission bell housing. Unfortunately there's not much you can do about it unless you remove the transmission to get at it. Mine did it for years before I finally replaced the clutch and was able to lube the pivot joint.
  5. Apr 15, 2009 at 1:43 PM
    Untamed_SS
    Untamed_SS Stayed Up Too Late
    Adam
    Haughton, Louisiana
    08 Speedway Blue Access Cab
    Alpine iDA-X200 Deck, Rockford P3, Infinity 1600 A Amp, Black Badges, "KnightRider Mod", Back-up lights. Painted Engine Cover. TRD QuickShifter & Shift Knob. MAF Calibrator. Doug Thorley LT Headers. Custom Y-Pipe. Flowmaster 50 series. Satoshi Grill
    Mine does the same thing. And I currently have my tranny on the ground. Where exactly do you lube it if you don't mind telling me. somewhere inside the bell housing?
  6. Apr 15, 2009 at 1:47 PM
    trtripoli
    trtripoli lower management
    Denver, CO
    07 4,0 L, 6M, Dbl Cab, TRD Off Road
    Eclipse AVN6620 JL 500/1 amp JL 13TW5 sub JL 300/4 JL XR-650CSi Mr Marv Box Blu tooth XM radio Back Up camera, RAAMmat and Ensolite everywhere but ceiling
    I had mine replaced on my '07 through my warrenty and it still squeaks when it gets warm. I recommend greasing it.
  7. Apr 15, 2009 at 1:51 PM
    bobwilson1977
    KaliFORN-I-A
    What you want to look for is the fork that runs outside of the bell housing. Its what pushes the thrust bearing back and forth. It is held in place by a small spring. When you remove it, you'll see a rounded ball joint looking thing. Its the only thing the fork rests on. I used high quality bearing grease because it is heat and dirt resistant. If I were you and I had the transmission out, I'd replace all of the stuff in there anyway - thrust bearing, clutch, or whatever because the parts are cheap enough, that is unless the clutch is new or has little wear. Might as well do it while you have it apart.
  8. Apr 15, 2009 at 1:52 PM
    bobwilson1977
    KaliFORN-I-A
    ohhhhhh.... wait a minute.... this is an 07'? Well mine is a 96. Not totally sure if the fork is the same on the new ones. But if it squeaks when you push it down, it surely has to be either the thrust bearing or thrust fork pivot.
  9. Apr 15, 2009 at 1:57 PM
    Untamed_SS
    Adam
    Haughton, Louisiana
    ^^ Cool man. Thanks for the info. Even though, as you stated, not exactly the same year model, I kinda know what to do now.
    Unfortunately my tranny is down due to "user error" as stated by the service manager. :rolleyes:
  10. Apr 15, 2009 at 2:01 PM
    trtripoli
    Denver, CO
    this has been posted a few times on here, but here is the TSB for squeaky clutch peddles for 2nd generations. It has a good diagram of the clutch assembly. I imgaine the 1st generation isn't too much different
  11. Apr 15, 2009 at 2:23 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    Do you hear it in the cab just above the clutch pedal? Or is it from under/outside the cab? If you hear it mainly from the inside, on my 99 there a few hard plastic bushings that eventually break and leave small bits on the floor board, look up Janster she did a complete write up on it, I'll look and see.
  12. Apr 15, 2009 at 2:26 PM
    Monkeysuncle
    Kevin
    Florida
  13. Apr 15, 2009 at 2:29 PM
    Untamed_SS
    Adam
    Haughton, Louisiana
    To me, it sounds like on the inside. But it really only sounds like something WD-40 can fix. I guess not though. :(
