clutch pedal squeak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GatorRock, Sep 26, 2017.
  1. Sep 26, 2017 at 9:13 AM
    GatorRock
    GatorRock [OP] Member
    Rocky
    2008 Tacoma 4x4 6spd man black
    Any body have any idea what i can do to get that squeak out of the clutch pedal when you depress the clutch and release it
  2. Sep 26, 2017 at 9:28 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    I got under there with a small pair of vice grips and tightened up the rod and it dont squeak any more.
  3. Sep 26, 2017 at 9:29 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    I feel your agony man!
    There's a TSB for it. =lube the components
    Real good job Toyota lol!
  4. Sep 26, 2017 at 9:29 AM
    dirty deeds
    Nick
    Eastern KY
    Hmmm...I need to try this
    bluezzy[QUOTED] likes this.
  5. Sep 26, 2017 at 9:31 AM
    NM Lance
    NM Lance Well-Known Member
    Lube it with white lithium grease where the plunger contacts the pedal assembly. It will be silent for a few months, then you will have to reapply it.
    Jere likes this.
  6. Sep 26, 2017 at 9:32 AM
    GatorRock
    Rocky
    what did you tighten up i will try it
  7. Sep 26, 2017 at 9:34 AM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    I don't have a clutch pedal:pout:
  8. Sep 26, 2017 at 9:38 AM
    BuddyS
    BuddyS Well-Known Member
    Maryland
    2013 TRD Sport 4x4 MT
    The TSB took care of the problem for me; going on a year now. Knock on wood.
    scottalot likes this.
  9. Sep 26, 2017 at 9:42 AM
    dirty deeds
    Nick
    Eastern KY
    Drive it more. Get dirt inside the vehicle.
    USE YOUR TRUCK lol
    It'll be back :devil:
    BuddyS[QUOTED] likes this.
  10. Sep 26, 2017 at 10:08 AM
    BuddyS
    Maryland
    :annoyed::bananadead::duel:
    dirty deeds[QUOTED] likes this.
  11. Sep 26, 2017 at 2:04 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    The TSB will not guarantee the squeak is gone forever. Mine came back with the TSB parts. What has cured it for now is to get a jar of never-seize that has a brush built into the lid and jam it into the pivot point between the pedal and shaft lubing it up really good. Some have reported some success with rotating the shaft 90degrees as well. That didn't last for me.
  12. Sep 26, 2017 at 2:11 PM
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    Mine was squeaking from underneath the truck by the main cylinder. I removed the boot on the bell housing and shot a small amount of white lithium with a straw at the end of the clutch fork. Had to use my phones camera and flash to see where to spray.
    That is if it's squeaking there. Careful spraying lube in there, use it minimally.
    It fixed it for now.
    scottalot, dirty deeds and vssman like this.
  13. Sep 26, 2017 at 2:36 PM
    Pigpen
    Dan
    Northwest Montana
    Mine has hardly made a peep since hitting it with lithium grease two years ago
  14. Sep 26, 2017 at 2:38 PM
    ANDROOO
    ANDROOO Well-Known Member
    Andrew
    PHX to SOCAL to PHX
    2013 Tacoma Reg Cab
    I got my toyota dealer to do the TSB still didnt work so they covered a full replacement for the clutch pedal assembly!
    scottalot and dirty deeds like this.
  15. Sep 26, 2017 at 3:28 PM
    dirty deeds
    Nick
    Eastern KY
    Well damn!
    Go ahead then haha
  16. Sep 26, 2017 at 3:29 PM
    ANDROOO
    Andrew
    PHX to SOCAL to PHX
    2013 Tacoma Reg Cab
    Gotta do what you gotta do!
  17. Sep 26, 2017 at 5:51 PM
    Saltnpepper11
    Saltnpepper11 Fabricator
    Mooresville NC
    2017 MGM TRD OR
    Grease it some more. and make sure all the bushings are in one piece my started squeaking on the 07 when one of the nylon bushings had finally worn through after about 80k
  18. Sep 26, 2017 at 6:28 PM
    Zach O
    Zach O Well-Known Member
    Zach
    Texas
    2015 TRD Off-Road SWFTMFW 6 speed
    Mine does the same thing. I have to use lithium grease every couple months. It gets bad enough that it seems to affect how smooth I can be with the clutch. It's really the only complaint I have with the truck.
