Clutch Pedal Sticking to Floor When Cold
Discussion in '3rd Gen. Tacomas (2016-2023)' started by godwinaustin, Jan 26, 2016.
  1. Jan 26, 2016 at 6:00 AM
    godwinaustin
    godwinaustin [OP] Well-Known Member
    Jon
    WYO
    2004 4x4 5VZ + 1982 4x4
    Currently in the single digits around here,
    Truck has 800 miles on it and the clutch pedal is sticking to the floor on startup, and will eventually return on its own. Seems sticky after that for a bit.
    This was an issue on a first gen I had, and although it was more pronounced it ended up being the clutch slave cylinder that was leaking and not allowing the system to maintain pressure.
    Could this be the same thing here, or is this just the fluid toyota uses?
  2. Jan 26, 2016 at 7:45 AM
    ppfd
    ppfd Well-Known Member
    WV
    09 TRD ext. cab 6 spd
    My 09 does the same thing. I'd say it is just the fluid being "thicker" in cold weather.
    Mine feels like it sticks for a second or two and returns up slow.
    No leaks on mine.
    No issue as it returns to normal feel in a few minutes.
    33yrsoftoys likes this.
  3. Jan 26, 2016 at 7:48 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    My 2003 TRD OR did this...can't remember the cause but the dealer had to replace a bushing or something.
  4. Jan 26, 2016 at 10:05 PM
    CaptainSkipper
    CaptainSkipper Active Member
    2016 QS TRD Sport DCSB M/T
    Several other members on this forum are having the same issue including myself, here's a link to another post about it.
    nevadabugle likes this.
  5. Feb 14, 2016 at 10:03 AM
    jeepinoutwest
    jeepinoutwest Well-Known Member
    -5º here and same issue, under 1000 miles. No leaks that I can see.
  6. Feb 14, 2016 at 10:13 AM
    COskimtb
    COskimtb Well-Known Member
    25 Sequoia TRD Pro
    Does warming the truck up for 5-10 minutes before driving help?
  7. Feb 14, 2016 at 11:41 AM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    My 2014 o/r did this as well, mine would go away after i drove about 10 min or if i warmed the truck up.
  8. Feb 4, 2017 at 5:49 PM
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    It's been in the 20's here this winter and the clutch pedal feels like a bunch of pudding when you press it down. I wonder sometimes if it will snap back. Strange.
  9. Feb 4, 2017 at 6:01 PM
    ievko82
    ievko82 Well-Known Member
    WV
    17 sport DCSB quicksand
    I had the same issue. Seems like it's gotten a little better after 4k miles.
  10. Feb 4, 2017 at 6:29 PM
    su.b.rat
    su.b.rat broken truck
    I'm not in extreme cold, but i can see the same thing, just less of it. in 20-30F it's a bit sluggish back to the top. wonder if changing the fluid could benefit?
  11. Feb 4, 2017 at 6:33 PM
    Stockotaco
    Stockotaco Well-Known Member
    Ben
    2016 Inferno TRD Off Road 4x4 w/man pedal
    All Stock
    One year ago when my truck was new, it experienced the same slow response. Today it was 18 degrees out and the clutch was normal. Maybe it has a break-in period.
  12. Feb 4, 2017 at 6:53 PM
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Mine has improved slightly with 23000 miles. Still sluggish on sub 20 degree weather but not as bad.
  13. Feb 4, 2017 at 7:07 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My 08 did not do this because the Clutch shared the Brake Fluid Reservoir, my 15 is a little slow in the cold after sitting a few days because the Clutch Reservoir sits out on the fender and is more exposed to extreme temps.
  14. Jan 4, 2022 at 7:48 PM
    Monty41
    Monty41 New Member
    Has anyone gotten any resolution on this? Mines been back to the dealer. They changed out the master and slave cylinders and the issue remains.
  15. Jan 5, 2022 at 5:59 AM
    TX BAJA1
    TX BAJA1 Well-Known Member
    2021 LUNAR ROCK TRD PRO
    My 2012 did it as well. Ok once it warms up. I believe it is normal.
  16. Jan 5, 2022 at 8:54 AM
    Jason J
    Jason J Well-Known Member
    oregon
    08 tacoma 4x4
    Try removing the spring on the clutch pedal. Shove the pedal to the floor and hold it and you can slide the end of the spring out of the pedal slot with some effort. Make sure you grab the bushing on the other end of the spring in case you choose to reinstall. This spring assists you when depressing the pedal but also adds resistance to the pedal being able to return back up.
  17. Jan 5, 2022 at 9:14 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    I have a mild issue with this in temps between 5F and 20F - def related to the fluid viscosity.. But, I am curious for those to did the ADM delete if their clutch performance changed at all in the cold?
  18. Jan 5, 2022 at 9:15 AM
    Clearwater Bill
    Billy
    Largo Florida
    @tonered would the 'delete package' you developed have any impact here?
    tonered likes this.
  19. Jan 5, 2022 at 9:20 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks!
    Folks have said that the ADM helps just a bit with the cold start pedal issue. It is not a complete cure.
    On my side with our recent cold snap (high teens in the afternoon), it was the first time that I felt the soft pedal starting up from work to go home. It took a while for it to feel normal but gave me no other issues with shifting.
  20. Jan 5, 2022 at 10:11 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    I wonder if DOT 4 LV (low viscosity) is compatible with the clutch hydraulic system? Viscosity at -40 is half of DOT 3 specs.
    supralee likes this.
