Clutch pedal sticking to floor
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bruno, Aug 6, 2013.
  1. Aug 7, 2013 at 12:55 PM
    Bruno
    Bruno [OP] Well-Known Member
    Bruno
    1996 4x4 V6 Xtra Cab 5spd
    1st Gen Fabtech Coilovers, Rear Add a Leaf, 33x12.5 BFG Mud Terrains, Deck Plate Mod
    I had my GF depress the clutch slowly and the slave didn't even move. It doesn't really tell me what the problem is between the two...it just means that it could be either. If it moved, it would have been the master for sure. In any case, I'm starting with the master.
  2. Aug 7, 2013 at 6:54 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    if it doesn't move, wouldn't that indicate the MC? that means no hyd pressure is getting to the slave cylinder.
  3. Aug 8, 2013 at 6:13 AM
    Bruno
    Bruno
    I think that is the likely scenario. I was thinking that if the slave was defective, it wouldn't move even if it were receiving pressure. In that case there would probably be a leak though.
  4. Aug 14, 2013 at 9:17 AM
    Bruno
    Bruno
    Update:
    Mission accomplished. Master cyl, slave cyl, new clutch fluid all swapped.
    I'd rate it a 3/10 on difficulty. Hardest part was getting the right amount of fluid in at the end, needed the gf's help. Took about 3 hours total.
    I used these instructions along with some posts in this thread:
    http://4x4wire.com/toyota/maintenance/clutchmaintenance/
    Not really any new advice that wasn't given. I adjusted the master cylinder to match the removed master cylinder, I can see why that would have been a pain had I not. I didn't remove the dash panel for better access to the cotter pin on the pedal, didn't need to. A one man bleeder kit probably could have avoided the GF...but I liked looking up her shorts from under the truck...so I'd do it the same way next time.
    Hope this might help somebody in the future...feel free to ask me anything.
    Total cost: $90 + 3hrs. Probably saved $400-$500? Just a guess.
    Kazimcsurf likes this.
  5. Oct 25, 2019 at 7:57 PM
    mayday
    mayday Well-Known Member
    Central Coast, CA
    99 5 speed 4x4 SR5 TRD Supercharged
    Sorry to go back an old write up. Experiencing the same problem with my clutch pedal. Any thing you would do different before I make the swamp for the master cylinder? Thanks!
  6. Oct 26, 2019 at 5:46 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 380k miles
    Toytec Boss/Eibach Coils & Deaver J59's
    @mayday Some people say it's unnecessary, but when I did this job I did a bench bleed on the master cylinder before installing it. Just run some short vinyl tubes from the side of the master cylinder up and into the reservoir, fill it with DOT3 and cycle the piston slowly until the fluid runs clear without any air bubbles. Install the unit with the tubes still in place to avoid a mess, then install the hard lines one at a time.
    Make sure to check clutch pedal height when adjusting the push rod length and use grease on the area where the push rod yoke attaches to the pedal to avoid squeaks.
  7. Oct 26, 2019 at 6:32 PM
    857975wstbygd
    857975wstbygd Wv Taco
    Hurricane, WV
    1996 2.7l manual trans, 4x4
    Wheels and mt Head unit 4 JBL door speakers 2 12in Skar Audio subwoofers and 1500 rms amp
    This happened to me a month or so ago and it was the master cylinder.
  8. Nov 17, 2019 at 8:26 AM
    mayday
    Central Coast, CA
    Just fixed mine as well. It was the master cylinder.
    Kiloyard likes this.
