Clutch Pedal Sticking to Floor
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hobro, Aug 10, 2015.
  1. Aug 10, 2015 at 2:00 PM
    Hobro
    Hobro [OP] New Member
    '04 White Tacoma 4x4 3.4L 6cyl
    2004 4x4 3.4L 6cyl EFI DOHC
    Hello everybody, have question about some problems I've been having with the Taco. After having replaced BOTH the slave and master clutch cylinders, I'm still having trouble with the clutch pedal sticking and having to pull it back with my foot. Bleeding the system seems to temporarily fix the problem, but a few days later it's right back. My first instinct is to say there's a leak somewhere in the line, but I'm not quite sure.
    What do y'all think?
    Thanks in advance.
  2. Aug 10, 2015 at 2:02 PM
    doyouevenprerun
    doyouevenprerun Well-Known Member
    Jake from state farm
    Gilbert, AZ
    02 TuRD
    just got a simple lift on her
    my friend had the same issue, but bleeding wouldnt really help.. right when he would push the clutch down, it would get held to the floor.
    he did the slave and master clutch cylinders and it didnt do anything, he ended up having to put in a new clutch, and that is what fixed it.
