Clutch pedal travel adjustment directions needed
Discussion in 'Technical Chat' started by motoretro, May 10, 2009.
  1. May 10, 2009 at 5:25 PM
    motoretro
    motoretro [OP] Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    My dealer and I have a disagreement on clutch pedal adjustment and specifications. He says it can't be adjusted......:rolleyes:. I know better. I have specs for 05-06 but my truck is a Taco 09 Reg cab, 2WD, 5 speed manual trans. I need a copy of 08-09 directions from shop manual and specs.
    Any help would be appreciated.
    Motoretro
  2. May 10, 2009 at 5:51 PM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    Alot of hydraulic clutchs are not adjustable. Im not saying that the taco is or is not.
  3. May 10, 2009 at 8:27 PM
    motoretro
    Michigan
    I understand what your saying although Toyota's 05-06 manual shows a adjustment procedure in depth. I just need current info on 09's to validate things. I don't believe a change has taken place since 06 although I'm not 100% sure.
    Motoretro
  4. May 10, 2009 at 8:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    As far as I know, No changes and the procedure is the same.
  5. May 11, 2009 at 5:43 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    The local dealer here told me flat out that it was a PITA. They probably just don't want to do it.
  6. May 11, 2009 at 10:59 AM
    motoretro
    Michigan
    The instructions don't look that difficult to me but it may very well be a PITA, I'm really not sure. At $80-90.00 an hour you'd think they could figure it out though. I have driven several new Tacomas and have noticed a variation in pedal travel.
    Motoretro
  7. May 26, 2009 at 10:16 AM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    I could use these too. Ever since I had my clutch pedal assembly replaced, I've found that the pedal sits too high. I could take it to the dealer and have them fix it, but that's kind of a PITA, so if it's something I could do myself, I'd rather do it.
  8. May 26, 2009 at 10:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This should help those with second gens that need to adjust the clutch peddle.
  9. May 26, 2009 at 10:23 AM
    TacoCo
    Colorado
    Perfect! Thanks Chris :thumbsup:
  10. May 26, 2009 at 10:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Anytime! :)
  11. May 26, 2009 at 10:48 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Dealers SUCK!
    OK, all of them that would just throw lame shit like this out!
  12. May 26, 2009 at 10:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LMAO!!
    Your just NOW comming to this conclusion? ;)
  13. May 26, 2009 at 10:55 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Nah, but it can never be reiterated often enough, LOL. Especially on shit as limp as no clutch adj even tho right there in the srvc manual.
  14. May 26, 2009 at 10:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LMAO!! It IS funny the shit that they DONT know about the vehicles they are "Supposed" to be "specialists" with.
  15. May 26, 2009 at 10:59 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Funny in an ass sucking time wasting we don't know shit but we'll talk shit & fake it for you sort of way.
  16. May 26, 2009 at 11:01 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2
  17. May 26, 2009 at 4:24 PM
    motoretro
    Michigan
    And I even have it in writing on paperwork......;)
    I'm not sure I want to have them adjust it now that I'm aware of their position on this. I will probably just do the job myself, Was hoping to avoid this with two blown discs in my back.
    Motoretro
  18. May 26, 2009 at 4:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You could always print out the link I gave, and take it to them. Ask "Can you follow these instructions, Please?"...Then Staple them to the guys head.
  19. May 26, 2009 at 6:06 PM
    motoretro
    Michigan
    Sounds like a Plan!!:infantry:
    Motoretro
  20. Sep 16, 2010 at 10:21 PM
    motoretro
    Michigan
    I did exactly that and they stated everything was in spec. I've driven it for a year and tried another dealer w/ Master Toyota Tech.....Same deal, in fact when I picked the truck up he said there wasn't any adjustment left for that. I showed him the third step in SM on HIS computer where clutch take-up is adjusted, he stood there w/ blank look on his face.........evidently he did not roll down to the third step!
    Perhaps someone can clear this up for me, If you adjust the pedal height to the minimal setting of 6.63" which is about .375 less my existing pedal height, will it also cause the clutch take up to be closer to the floor? Seems like it would.
    I honestly feel these trucks would drive a lot better with clutch take-up closer to floor. The combination of poor seating position, throttle by wire and high clutch take-up really makes driving the truck a less than smooth procedure. I would love to crawl under there and adjust this correctly although w/ my back so screwed up they would probably have to bury me in this position!:ohsnap:
    Motoretro
