Clutch Pedal
Discussion in '4 Cylinder' started by Fredneck, Oct 8, 2009.
  1. Oct 8, 2009 at 5:06 PM
    Fredneck
    Fredneck [OP] Active Member
    Wyoming
    09 2.7L Tacoma
    BONE STOCK for now
    My clutch pedal has developed a annoying creaking noise that is starting to get on my nerves :mad:
    Has anybody else experienced this? How can I fix it? Don't have any desire to take my truck to the boneheads at the dealer.
  2. Oct 8, 2009 at 6:12 PM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    There's a TSB on this - search 'em and you'll find it!
    From what I understand, the dealer will replace parts and fix it - only to have it happen again later, usually out of warranty.
    Someone here had what they thought was a permanent fix (it's been a design problem for 10 years with Tacos) but I have yet to try it. I just put up with the creak!
  3. Oct 8, 2009 at 6:18 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    This is a very common issue with the clutch pedal, and I actually have it myself. It seems to kind of come and go, but it very annoying when it is present. As much as you would like to not go to the dealer, I would go let them check it out. Don't take there bs "we'll lubricate the assembly" stuff either, get them to preform the TSB.
    Use the search function to find the other threads on this issue. It also wouldnt hurt to print out the TSB and take it to them.
  4. Oct 8, 2009 at 6:18 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Mine creaks too! We were able to cure it for about a week by soaking the entire clutch area with WD-40. Does yours go away after it's warm?
  5. Oct 8, 2009 at 7:30 PM
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    Mine does it too - and I hate it. It started within the first couple thousand miles... and seems to be worse when the interior is hot (like after it's been parked outside in the sun for a while). I also don't want to take mine to the dealership for the TSB, but I may have to break down and do it - even if it is a temporary fix. I can't believe Toyota has kept using that crappy design for 10 years!!! Lame.
    I'd like to get a clutch pedal assembly out of a junkyard and try to figure out a way to put a real bearing in there instead of that B.S. plastic bushing. THAT would be a fix.
  6. Oct 8, 2009 at 7:46 PM
    Fredneck
    Wyoming
    09 2.7L Tacoma
    BONE STOCK for now
    I found a TSB but it's for 05 and 06 Tacoma's, my trucks an 09.
    View/download it here >>> http://www.divshare.com/download/4099480-549
    I'm going to assume the Dealer won't perform the TSB on an 09 due to production changes were supposed to fix the problem.
    I guess I'll try and shoot the pivot bushings with some lube probably using some lithium white grease.
    Does anybody have a TSB that applies to an 09?
  7. Oct 9, 2009 at 8:15 AM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    Yep, mine too...at around 3k miles.
    Becoming very annoying.
    PC
  8. Oct 9, 2009 at 6:12 PM
    SC4333
    Grant
    San Antonio, TX
    My truck is a '08 and I was specifically told by the service manager that they are allowed to carry over certain TSBs and apply them toward later model trucks where the issue that has not been resolved. This was one of those cases. I never went back to have the work done, although he was ready to perform it. Definitely worth a shot IMO.
  9. Oct 9, 2009 at 7:43 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2009 Tacoma Regualr Cab 4x4 2.7L
    I just re-lubed the lubrication points called out in the TSB and my squeak went away. Already have the updated parts.
  10. Oct 9, 2009 at 8:26 PM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
  11. Oct 13, 2009 at 6:50 PM
    Cappy Cap
    Cappy Cap Well-Known Member
    Boston
    08 Reg. Cab
    K & N Intake, Alpine S-10 Shallow Mount Sub, Alpine CDA-9884 H/U, Alpine Type-R Components, Alpine Amp, 3.73 rear end, Welded on Muffler, Bug Deflector, Rain Guards, LCE Short Shifter,
    I had the same thing happen to my truck... went to the dealer 5 times the first 4 couldnt figure it out... finally the last time they got it right called toyota and everything... hasnt creaked for about 7,000 miles
  12. Oct 14, 2009 at 1:23 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    My Tacoma is out of warranty, so no TSB for me. Here is a link that fixed my squeaky clutch.
  13. Oct 14, 2009 at 8:32 PM
    MowTaco
    Kansas
    Has anyone determined if the problem is the same on 1st gens? I know it's not a serious problem, but it annoys the heck outta me.
  14. Oct 21, 2009 at 1:00 PM
    z33tec
    z33tec Well-Known Member
    Rochester, NY
    09 4X4 Access Cab 4cyl
    Had this same issue with my 09 with about 4500 miles on it. When I took it in for my first oil change I told them about it and it said they lubricated it due to customer request on my receipt. The creaking noise is gone but I haven't driven it very far since they have done it. They just did it last weekend.
    I'm hoping it doesn't come back but if it's a lubrication issue it's only a matter of time.. Didn't realize there was a TSB for creaky clutch pedals. If it comes back I will have to bring that up next time.
  15. Oct 26, 2009 at 10:08 AM
    AGumbus11
    AGumbus11 Member
    Andy
    Milford, CT
    This happens on all Toyota clutches after some time. My 92 Lexus Sc300 does it...my 93.5 Supra did it....my friend's 87 MR2 does it...
    I use white lithium grease on any moving part to my clutch pedal assembly - it works for a couple months (usually until it gets really cold out) and then I'll need to reapply.
  16. Oct 26, 2009 at 11:48 AM
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    '10 TRD SPORT Acc.Cab Mag Grey 4x4 Auto
    Weathertech floor liners, stone and bug deflector, Putco Element In Channel Window Visors, Viper remote starter, Harley lighted hitch cover, Herculeze front mudflap, Metal Miller Harley Grill Emblem, SockMonkey design Bedside Decals and 3rd Brake light TRD decal, K&N Air Filter, Goodyear Duratrac 265/70/17 C load, Valor Exhaust tip, De-badged tailgate, Advantage Tonneau Cover, Tacoma bedmat, Bicycle Mount Rail mounts, Custom Ipod holder. Stock Suspension :( (winter wheels: 2014 16" stock steel wheels plastidipped black with general arctics 265/75/16)
    My dealer fixed my creaking clutch free.
  17. Oct 26, 2009 at 9:46 PM
    silverback
    silverback Well-Known Member
    central CA
    2006 Prerunner SR5
    painted door handles, bilstein 5100's front and back, K&N air filter. Precision power component speakers and Kenwood deck.
    I dont have a creaking clutch but I did notice when I was sitting at the drive thru there was a slight rattle sound when the clutch was let out. when I press the clutch in it goes away. When I owned a Wrangler I noticed this also . Is this normal I have a warranty but I doubt that the clutch area is covered. Thanks for any information you all might have.
