Clutch pedal !!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacovince, May 17, 2010.
  1. May 17, 2010 at 1:55 PM
    tacovince
    tacovince [OP] New Member
    Vince
    NY
    04 taco trd
    Hi all,
    I have a 2004 tacoma trd Sr5 v6 xtra cab with a 5 speed that has 140,000 miles on it. Last week the clutch pedal started making noise every time it was pushed and released. Come to find out the 2 plastic flange bearings in the pedal frame that are used to isolate the return spring have worn out. Does any one have a site where I can order these? Don't want to go to the stealer ship yet. I still need my arm and leg. LOL
    Thanks
    Vince
  2. May 17, 2010 at 2:02 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    That's a very common problem on the tacos. Here is a write up on the fix.
    http://www.lieblweb.com/clutchbushing.html
    For the '96 in the article, the part was: [FONT=Arial, Helvetica, sans-serif] [/FONT][FONT=Arial, Helvetica, sans-serif]Toyota Part #[/FONT][FONT=Arial, Helvetica, sans-serif]90389-05017[/FONT]
  3. May 17, 2010 at 7:47 PM
    tacovince
    Vince
    NY
    04 taco trd
    That is excellent, i did a search but came up empty handed, this answers all the questions. Appreciate the help.
    Vince
  4. May 17, 2010 at 8:23 PM
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    Mine started squeaking also. But it was a simple fix. I determined the noise was outside. I pin pointed the problem, it was the slave cylinder. I just sprayed the little rubber boot on the slave cylinder and the noise went away.
  5. Jun 16, 2010 at 12:15 PM
    Quast
    Quast Well-Known Member
    Dustin
    Mission, BC
    03 toyota tacoma 3.4L
    3'' OME lift, Deck plate mod, spidertrax wheel spacers, 12'' alpine type S sub.
    stupid question im sure but where can one buy this bushing? is it something you just go to the stealership for or can it be bought at a auto parts store aswell? searched some posts but havent been able to see one?
  6. Jun 17, 2010 at 2:26 PM
    tacovince
    Vince
    NY
    04 taco trd
    Hey,
    I went to the stealership and paid about 2.50 for each of the bushings, 3 in total. One for the pedal to the spring and two for the spring to pedal bracket. You can find them cheaper online but time you pay postage & handling it will probably be more. It took them two days to get and the job took twenty minutes. Worked like a charm by the way, no more pedal noise.
    Vince
  7. Jun 17, 2010 at 3:21 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Be prepared to replace those things every couple years. I replaced mine about 3x in 5 or so years (on my 96)
