Clutch Petal Squeeking
Discussion in '1st Gen. Tacomas (1995-2004)' started by trussell456, Mar 4, 2012.
  1. Mar 4, 2012 at 10:01 AM
    trussell456
    trussell456 [OP] Well-Known Member
    Tyler
    Maine
    03 TRD V6 5-Speed
    Bilstein 5100's / Eibach's / AAL / All Pro Front Bumper / Skids / Billet Grill / 33x12.5x15 Duratracs / Dick Cepek DC-2's / TRS Retrofit / 20" Light Bar / 6" HID Fogs / Wet Okoles / WeatherGuard Tool Box
    like title says, my clutch pedal has an awful squeak when i press it. I tried oiling everything under the dash that was visible, but it sounds like the spring that is squeaking. I know people use silicone spray for springs on garage doors, do you think it would have the same effect on the clutch pedal spring?
  2. Mar 4, 2012 at 10:03 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    This is a common problem. At the top of this forum, there is a Search button. Lots of information about this topic already.
    Here's a writeup I made many many years ago on my 96.
    http://www.lieblweb.com/clutchbushing.html
    Good Luck
  3. Mar 4, 2012 at 10:06 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    mine actually squeaks where the pivot arm from the slave cylinder goes into the transmission
  4. Mar 4, 2012 at 11:42 AM
    2000GTacoma
    Snow Hill NC
    i just carefully sprayed some brake cleaner in there and then a little silicone water resistant grease or what you like to use. just be careful as you dont want to get the spray on the clutch
  5. Mar 4, 2012 at 11:46 AM
    6spdtaco
    6spdtaco Well-Known Member
    Nate
    East Wallingford, VT
    Taco
    Tom Woods driveshaft. TRD short throw shift kit. TRD exhaust. AFE Stage II intake. CBI Bumpers front and rear. Warn 8000i winch/ synthetic line. OME 3" lift w/ dakar springs and 886 coils. ATO Front skid. ARE MX cap. Trail Team FJ wheels. Cooper Discoverer ST 265/75-16 C tires. Diff breather relocation mod.
    petal=flower
    pedal=truck
    oh and squeak, not squeek.
    Sorry I can't actually help with a solution to your problem, looks like others have got you covered there.
  6. Mar 4, 2012 at 3:54 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    +1 My buddies is squeaking at the bushing so that's where I assumed mine was coming from. Just replaced the clutch and lubed up all of the pivot points and my squeak is gone. Looking back now, it makes sense because his was really loud all of the time (coming from inside the cab) and mine was much louder with the window down than up (coming from outside the cab).
