Clutch problem: Shifting problem from 1st to second. Metal on metal filling.
Discussion in '4 Cylinder' started by egres, Mar 1, 2014.
  1. Mar 1, 2014 at 6:26 PM
    egres
    egres [OP] Well-Known Member
    DELCO PA
    13 singel cab - 2WD - manual - 17K before tax:)
    Bench-seat covers $180 (Can't believe its not leather),Bed Liner $375 (Bed rug), Roof rack $180 (Rhino-rack 2500 Series, plus DK clamps and pads), Modified Bed extender $85 (Extend-A-Truck 944 Truck Bed Extender), Hood lift assist $80 (RedlineTuning), Hood light $53 (tacomaworld.com âtacodaneâ), Hitch receiver $120 (Curt Manufacturing 13323 Class III Receiver), T connector for trailer $43 (CURT Manufacturing 55513 T-Connector), Manuel tailgate lock $30 (gatekeeper tailgate lock), Tailgate assist $28 (Sachs SG329900EZ Lift Support), Tailgate lock $67 (Pop & Lock Tailgate Lock Tailgate Lock PL5301), Spare tire lock $12 (Trimax ST30 Trimaflex Spare Tire Cable Lock), Hardwired battery float charger $20 (Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps) , Vin # Glass etching $33 (vinguard.org), Easy oil drain plug $30 (Fumoto Engine Oil Drain Valve), Floor mats $80 (Husky Liners 2-Piece Front Liner 2-Piece Front Liner), out of space :)
    2013 4 cylinder. Just started, for last 50 miles. When shifting from 1st to 2nd, right after natural and going in second, I can fill metal on metal contact, little resistance and scratchy. I can fill it on the shifter and clutch pedal. And hear little thump.
  2. Mar 1, 2014 at 6:32 PM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    Bad synchronizer? What's the temp there? Is it still doing it at operating temp?
  3. Mar 1, 2014 at 6:36 PM
    egres
    DELCO PA
    BTW Other gears are ok, not great but don't have that resistance like 1st to 2nd. I drove civic and gears shift much better then taco. My bud says, since my truck is new, it will probably will improve. But thinks that 1st to 2nd is not normal.
  4. Mar 1, 2014 at 6:38 PM
    egres
    DELCO PA
    Yes it does. After 10 miles it was still doing it. Thank you.
  5. Mar 1, 2014 at 6:45 PM
    egres
    DELCO PA
    The truck is new, is it possible that it's factory defect?
  6. Mar 1, 2014 at 6:52 PM
    vstrom
    vstrom Well-Known Member
    It's new.. everything will take time to 'break' in. Also, it's a truck, so it will never shift as smooth as a car. It will always be a bit clunky.
  7. Mar 1, 2014 at 6:53 PM
    SoutheastTaco
    steven
    columbia sc
    09 trd sport dc 4x4
    It's possible, but not likely. Have a tech at the dealer drive it and see what their opinion is.
  8. Mar 1, 2014 at 7:30 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    That would be the four cylinder second gear crunch. Gets worse in the winter.
    Solution, don't use GL5 oil, and shift slower. I let the shifter center in neutral before flicking it back to 2nd and that's usually enough time.
    Sometimes revving it up to around 3000 rpm makes it go away too.
  9. Mar 1, 2014 at 7:59 PM
    egres
    DELCO PA
    Wow it's know problem and has a name? [​IMG]
    I have one reservoir that combined with brakes. So my clutch fluid is dot 3.
  10. Mar 1, 2014 at 8:44 PM
    iroh
    michigander
    tonneau
    Nah, I wasn't referring to the brake fluid. The tranny's oil is 75w-90 GL4 from the factory, so you're ok for now. The manual says use GL4 or GL5 75w90 when changed out but GL5 is almost guaranteed to make bad shifts. It doesn't play nicely with the synchros.
    Mine does it every time when the tranny is cold, partly because I don't rev the motor much and it's been below zero so often. After running for about 15 minutes it pretty much goes away.
    In the summer I'll get one or two cold crunches if I rush things and then it's done for the day. Nowhere near as annoying.
  11. Mar 4, 2014 at 6:00 PM
    rodney
    rodney Well-Known Member
    Toyota Sienna Mommyvan & Ford 2fitty
  12. Mar 4, 2014 at 6:04 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    It's a Bear to shift when cold, for sure. 98k on mine; don't worry about it. "Second gear crunch"...that's a good one.
  13. Mar 4, 2014 at 8:01 PM
    egres
    DELCO PA
  14. Mar 5, 2014 at 9:11 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Mine does the same thing, gets better as the trans warms up. Just shift slower. Hondas and Toyotas are massively different, my wifes Honda Fit is the smoothest shifting car Ive ever driven, and my truck is the most dramatic. Everything else falls between them somewhere lol
  15. Mar 6, 2014 at 5:50 PM
    hoenah808
    hoenah808 Well-Known Member
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    well ive owned lots of older toyota 4x4s all 5speed. my 2014 I had to get used to the shifting as well as the clutch pedal...I now learned to shift out of gear to neutral then into 2nd gear, not 1st to 2nd super fast, doing so makes a much smoother shift
