Clutch problem?
Discussion in '1st Gen. Tacomas (1995-2004)' started by DustStorm4x4, Aug 7, 2015.
  1. Aug 7, 2015 at 9:24 PM
    DustStorm4x4
    DustStorm4x4 [OP] BBC 2020
    U S A
    04 Jeep LJ
    Ok so I just bought a 2001 Tacoma V6 4WD. (My first manual ever :anonymous:)
    I drove it and everything was riding nice UNTIL I parked it at home. When I got back into the car, I turned it on, let it warm up a bit, and: I couldn't put it into gear. No matter how hard I pushed... Nothing. I sat for like 12 minutes just trying to figure it out. I pushed in the clutch in all the way. It just wasn't going into gear. Any gear.
    I finally figured out that it was the clutch pedal. I had to sort of pull it my way a little. Its almost like it doesn't want to go all the way up again. So now, I figure, I have to pull the clutch pedal a little and then push it in and then start and go.
    So here's the question. What the heck is the problem? Is that normal? Is it a safety feature or what? Sorry for the long story, just paranoid about the problem.
  2. Aug 7, 2015 at 9:28 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Sounds like the master cylinder is going.
    Justus likes this.
  3. Aug 7, 2015 at 9:31 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    o_O what if I'm on flat land?
  4. Aug 7, 2015 at 9:32 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Awesome. Any guess on how much that will be?
  5. Aug 7, 2015 at 9:36 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    rockauto.com has them for $20-40. Plus a large bottle of DOT3.
  6. Aug 7, 2015 at 9:37 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Ok cool. Not that expensive. Any idea on how hard it is to do yourself?
  7. Aug 7, 2015 at 9:41 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Search on here and you will find the service manual for your truck. Or google and you should be able to find a PDF version you can get for free. It's not that hard, just messy. Drain the fluid as best you can, discount from pedal remove the lines, unbolt, and bolt on the new one. Put it back together in reverse order. Bleed it after your done. BSD (Beard Scale of Difficulty) is a 2.
  8. Aug 7, 2015 at 9:47 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Cool. Thank you so much. I'll try it as soon as I can.
  9. Aug 8, 2015 at 12:14 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    So it wouldn't go into first gear? Next time slip it into second gear first then go up to first. Or while holding slight pressure like trying to get it in to first slowly ease up on the clutch a bit and it will go in.
  10. Aug 8, 2015 at 12:16 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    It wouldn't go into any gear. Not reverse or anything.
  11. Aug 8, 2015 at 12:30 AM
    vern650
    brandon
    hyrum, ut
    That's where the second part of my suggestion comes in, your trying to line up teeth on gears that have been spinning separate from one another, they're not always gonna line right up. Sometimes you gotta let up on the clutch a bit to give things a little bit of a spin to help things mesh.
    Speedytech7 likes this.
  12. Aug 8, 2015 at 1:51 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Solid advice, especially if it is your first time driving manual. But don't try and force the stick, that is a great way to end up with a bent shift fork and a hefty rebuild fee for a tranny. Just let the clutch out super slow until the stick goes into gear and then push the clutch back in. This is just gonna line up the teeth.
  13. Aug 8, 2015 at 4:40 AM
    gearcruncher
    Canadain bumper technician
    look under my user name for your transmission . i have aĺl the info you need to fix your hydraulic clutch problem
  14. Aug 8, 2015 at 10:33 AM
    Joe_from_iowa
    Joe_from_iowa Well-Known Member
    Joe
    2001 Tacoma TRD
    Yeah sounds like the master clutch cylinder. Mine has been doing that intermittently. Just bought it 3 weeks ago. Looked under the dash and the seal is leaking on the master cylinder. Looks like it was recently rebuilt as the seal and push rod look brand new. I ordered one from Amazon that will be here next Wednesday. Good luck with yours. It looks like it'll be an easy fix.
  15. Aug 8, 2015 at 11:03 AM
    trx125
    trx125 Well-Known Member
    I would suggest replace master and slave cylinders at the same time, bleed the system and call it done.
    Chipskip likes this.
