Clutch Problems I Think
Discussion in 'Technical Chat' started by JimmyIvine, May 12, 2009.
  1. May 12, 2009 at 1:27 PM
    JimmyIvine
    JimmyIvine [OP] Active Member
    Alberta
    2.7 Liter
    3 inch lift
    Hey I just took my 4 cylinder Tacoma for a little run through the woods and like all Toyotas it was a Champ!
    However 2 min out of the woods my truck just stop excellerating basiclly it was like it wasn't going in gear. I tried 2x2,4x4 and 4 low and they all had the same response.
    Basically I can put my truck in gear 1st 2nd whatever and take my foot off the clutch and my truck wont even stall or excellerate when I give it gas,just the RPM's go up.
    Truck starts fine sounds good, but it seems like its not getting engaged in a gear, is my clutch blown?
    Any Ideas?
  2. May 12, 2009 at 1:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Didnt this already get answered in another thread you started about this very same thing?
  3. May 12, 2009 at 1:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  4. May 12, 2009 at 1:33 PM
    JimmyIvine
    Alberta
    2.7 Liter
    3 inch lift
    Yeah that was me but it didnt get answer so im putting it in the technical section
  5. May 12, 2009 at 1:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    FL Forester gave a sound input. I seconded it. Sounds like your clutch is burned , or the Tcase is stuck in neutral. You may want to drop the tranny and look at the clutch.
  6. May 12, 2009 at 1:42 PM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    There's a remote possibility that you could have gotten some water up in the bell housing which would cause it to slip. Couple of questions: Is the transmission actually engaging the gears? Do you smell anything burning? Do you hear anything when you engage? I'm wondering if you screwed up something with some of the linkage.
  7. May 12, 2009 at 1:50 PM
    JimmyIvine
    Alberta
    2.7 Liter
    3 inch lift
    I don't smell anything funny or burning and there's no noise when I put my truck in gear. and Im not a wizz when it comes to my clutch but "screwed something up with the linkage?
    O and my engine light is on aswell
  8. May 12, 2009 at 1:54 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    I like Chris' idea. I think the tcase is stuck in nuetral. Especially since you were just offroad when this problem started, JMO. Good luck.
  9. May 12, 2009 at 3:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Being as your engine light is on, go have the code scanned. It may be more cost affective to buy one to keep on hand. You should be able to find a decent one for around $100.00
  10. May 12, 2009 at 3:22 PM
    Untamed_SS
    Untamed_SS Stayed Up Too Late
    Adam
    Haughton, Louisiana
    08 Speedway Blue Access Cab
    Alpine iDA-X200 Deck, Rockford P3, Infinity 1600 A Amp, Black Badges, "KnightRider Mod", Back-up lights. Painted Engine Cover. TRD QuickShifter & Shift Knob. MAF Calibrator. Doug Thorley LT Headers. Custom Y-Pipe. Flowmaster 50 series. Satoshi Grill
    Is your clutch hub seperated from your clutch pad. Sounds stupid huh? LoL Happened to me.
    Could put it in gear and let off the clutch, but no action... Probably not but...
    Try the transfer case like they said already. Good Luck.
    Edit: Just realized a couple things. Sorry for being late... 4 banger and 1st gen. I don't know if yours could have seperated like mine. Anyways, I was just throwing it out there. Sorry for being uneducated. :( :D
  11. May 12, 2009 at 3:34 PM
    JimmyIvine
    Alberta
    2.7 Liter
    3 inch lift
    Thanks for everyones feed back so far... it all helps.
    Chris you said something about getting the code scanned? do you mean like run a diagnostes test.... and what kind of information will that give me by having it scanned?
  12. May 12, 2009 at 3:38 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    yeah, hook up a OBD2 scanner and get the code, then look it up to see what tripped the CEL. Might tell you the problem or at least put you in the right direction.
  13. May 12, 2009 at 3:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What He said ^^^^^^^
  14. May 12, 2009 at 3:46 PM
    JimmyIvine
    Alberta
    2.7 Liter
    3 inch lift
    Perfect...K so were could i pick a OBD2 scanner (and dose OBD2 stand for something) And tripped the CEL what's that. Everyones been a major help so far for me to tackle this problem.
  15. May 12, 2009 at 3:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Any auto aprts store should carry OBD2 scan tools. Get one. Personally, it sounds to me that your clutch is fried.
  16. May 12, 2009 at 4:10 PM
    RelentlessFab
    Eric
    OBD= On Boad Diagnostics port; The '2' stands for 2nd generation OBD port. The original OBD was pre1996, 1996 and newer have OBD2.
    CEL= Check Engine Light.:cool:
  17. May 12, 2009 at 4:13 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    if the transfer case was in neutral wouldn't the rearwheels get power? I have a 99 manual hub tacoma. just a question???
  18. May 12, 2009 at 4:19 PM
    RelentlessFab
    Eric
    Nope, they wouldnt. you have to have it engaged some way. Ex. 2hi, 4hi or 4low without hubs would still give 2wd, or locking the hubs in 4hi or low will obviously give you 4x4.
  19. May 12, 2009 at 4:47 PM
    JimmyIvine
    Alberta
    2.7 Liter
    3 inch lift
    So basically the feedback im getting is my clutch is messed.. but before im gonna come to that conclusion im gonna try everything that was suggested first.Keep the suggestions coming.
    I just wanna thank everyone so far for all the feedback!
  20. May 12, 2009 at 5:30 PM
    Monkeysuncle
    Kevin
    Florida
    So I went outside, manually locked in the front locking hubs, transmission in 1st, xfer case in 4 high works great, transmission in first and 4 low works great, transmission in 1st x fer case in Neutral no go, so I stand corrected. All this on a 1999 v6 4x4 manual trans and hubs
