clutch problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by cezar, Oct 24, 2008.
  1. Oct 24, 2008 at 8:27 PM
    cezar
    cezar [OP] New Member
    k&n
    hey guys, noob here, i was googling for help and came across the forums. i guess this will be my intro thread and first help me please thread. i have a 96 tacoma, faded red with about 108K on the clock. ran into my first real problem with her recently. the truck was loaned out to my sister (she needed it to move) and against my better judgement i let her use it, when she brought it back the clutch didnt feel quite right, and if i held it depressed at a stoplight, it would release really slow. well i replaced the clutch slave cylinder after some advice from a family friend. inspecting the old one showed that it was sticking a bit. on the test drive though, i came to a stoplight and had the clutch depressed as well as the brake. the motor started to sputter like it wanted to stall, i released the brake and the truck started moving forward with the clutch still depressed. :eek: what would make the clutch engage with the clutch depressed? it shifts fine while driving. sorry for the long post, and any help will be greatly appreciated.
    thanks
  2. Oct 24, 2008 at 8:48 PM
    tacoma-king
    tacoma-king Well-Known Member
    sault ste. marie Michigan
    1997 Tacoma
    hitch
    did you bleed it to make sure there was no air in it after you replaced the slave cylinder
    if there is air in the system the air will compress and the clutch will not fully disengage
  3. Oct 24, 2008 at 8:55 PM
    cezar
    k&n
    yes, i bled it and im pretty sure i got all the air out. it was kinda sticking to the floor a bit before i replaced the slave cylinder also if i held it for a while. it seems to engage and disengage fine while driving though.
  4. Oct 25, 2008 at 2:51 PM
    cezar
    k&n
    edit
  5. Oct 25, 2008 at 3:51 PM
    mudjunkie
    mudjunkie Well-Known Member
    clearwater fl
    96 tacoma sx l
    header,short rack and pinion, heavy duty shocks, grill guard, flowmaster exhaust,pacesetter header without catalytic converter, one 10 inch xant sub with a mtx amp, off road lights,diamondplate tool box,rhinolined inside cab,ngk plugwires.
    hey it really does seem like you need to bleed it more especially if you replaced both the slave and master cylinder
  6. Oct 25, 2008 at 4:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2.
  7. Jan 15, 2015 at 9:57 AM
    Silvert
    Silvert Well-Known Member
    Jeff
    Wisconsin
    2010 Tacoma reg. cab.,5sp., 4 cyl.
    clutch problems? contact this guy=
    Toyota person who respond to me-
    Alex Mendoza
    Toyota Customer Experience
    Toyota Motor Sales. USA
    19001 South Western Avenue
    Torrance, CA 90501
    800-331-4331
    5:00am-6.00pm
    WRITE, TELL OTHERS TO WRITE, BUG THEM !!!
  8. Jan 15, 2015 at 10:49 AM
    Madjik_Man
    Boulder County
    1998 Ext Cab 3.4 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    dafuq?
    You just bumped a 6+ year old thread for that? :confused:
