Clutch problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blitz, Apr 5, 2012.
  1. Apr 5, 2012 at 6:02 PM
    blitz
    blitz [OP] Well-Known Member
    Kevin
    cape cod
    Last night it started. My truck is an ’05 TRD Sport with 158k mi. when I push down on my clutch it feels fine, but when I let go it lags behind my foot and then lets go all at once. This makes it hard to drive and I think it will only get worse. My question is, is this a problem with the master cylinder, slave cylinder or clutch plate. I guess it could also be the pressure plate. If anyone has had this happen to them please let me know, also if anyone could tell me what to expect to pay for a clutch replacement that would be great. Btw I do tow a 5000 lb boat with my truck, and spend a lot of time off road.
  2. Apr 5, 2012 at 6:07 PM
    Paulie
    Paulie Well-Known Member
    Paulie
    USA
    Tacoma
    It will get worse, so look at it as an opportunity to put in a better assembly. HR clutches kick ass. Good luck.
  3. Apr 5, 2012 at 6:25 PM
    blitz
    Kevin
    cape cod
    hr clutch?
  4. Apr 5, 2012 at 6:37 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    10 to 1 it's the throwout bearing binding up. I had a Civic do that once about 7 years into its life. The nose on the tranny had the grease dry up and it caused that exact problem.
    Found out I replaced the clutch unnecessarily on that one. Honda CV boot grease on the nose, smooth as silk for years.
    Can't say I'm surprised, your truck likely has the old revision fork and throwout bearing that wears the nose more. I bet you'll be looking at the URD bearing soon.
    Clutch problems are *usually* failure to release, or slipping caused by wear or a blown pressure plate, not a delay in engagement. Usually.
    Anyone wanna second my opinion?
    (unhook the frigate from the hitch, might help... haha)
  5. Apr 6, 2012 at 1:11 PM
    blitz
    Kevin
    cape cod
    just found out that it is the clutch master cylinder. thank god its only a $112.67 fix! i might just do a DIY
  6. Jan 15, 2015 at 9:54 AM
    Silvert
    Silvert Well-Known Member
    Jeff
    Wisconsin
    2010 Tacoma reg. cab.,5sp., 4 cyl.
    Toyota person who respond to me-
    Alex Mendoza
    Toyota Customer Experience
    Toyota Motor Sales. USA
    19001 South Western Avenue
    Torrance, CA 90501
    800-331-4331
    5:00am-6.00pm
    WRITE, TELL OTHERS TO WRITE, BUG THEM !!!
  7. Jan 15, 2015 at 12:54 PM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    lol wut
