Clutch Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rowlock, Dec 27, 2011.
  1. Dec 27, 2011 at 9:33 AM
    Rowlock
    Rowlock [OP] New Member
    NW Florida
    Good day to you all. New member here with limited mechanical experience....well, when it comes to vehicles anyway. I've done some searching on the forum to see if I can diagnose my issue with a few ideas. Here's what I've got going on. I have a 97 Tacoma, 3.4L V-6, 4x4. It has about 163K miles. When I depress my clutch pedal, it shifts fine, but releasing the clutch it doesn't come back up all the way....I'd say about 3/4 the way back up so I pop it back up every time with my foot. I changed the master cylinder out awhile back. I've seen posts about bushings being changed out for the same symptoms but some not being the fix. I'm thinking of starting with bleeding the system (the reservoir is full so I am assuming there are no leaks) and then going from there. Any recommendations? When should a clutch be changed out? Any help would be greatly appreciated.
  2. Dec 27, 2011 at 10:05 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    It's either clutch master,slave, or crap in the fluid.
    As you said, start with bleeding the system. If that doesn't work, my money's on the slave cylinder.
    Oh, and welcome to TW :thumbsup:
  3. Dec 27, 2011 at 6:27 PM
    Rowlock
    NW Florida
    Thanks all.....many thanks.
  4. Dec 27, 2011 at 6:37 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    what about that spring inside the cab? the one for the clutch pedal itself
  5. Dec 27, 2011 at 9:56 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    what he said.
    If the clutch isn't slipping its probably fine. This sounds like a hydraulics problem.
    Probably your slave cylinder.
  6. Dec 28, 2011 at 9:40 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Trust me, if you have air in your system, or a blown master/slave, that pedal is not going to come back up. It has nothing to do with the spring in the cab. I only know this when I had my engine/transmission out of my truck I ended up bleeding the system and it was a PITA cause I kept having to manually pull the pedal up every time.
