Clutch question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 80schild, Apr 26, 2017.
  1. Apr 26, 2017 at 5:47 PM
    80schild
    80schild [OP] Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    hi everyone, I am considering buying a 2006 PreRunner 4cyl/5spd manual. It has 194k miles on it but it's pretty good looking truck overall. It runs and drives great, but the only problem is the clutch... for some reason the clutch pedal has to be pressed all the way to the floor to disengage the clutch, and then it engages after letting off of it the slightest bit. Simply letting off of the pedal an inch starts the truck moving. Does this sound like the clutch is bad, or is there a way to adjust the pedal?
    Also, the mileage does concern me.. about how long do these 2.7 engines typically last before they start burning oil or spinning bearings? I revved it up a few times and didn't see any blue smoke from the exhaust. The guy is asking $8k firm, and honestly ive never spent that much for a vehicle with such high miles, but I do like this truck.
  2. Apr 27, 2017 at 12:54 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Spare Parts likes this.
  3. Apr 27, 2017 at 2:51 AM
    80schild
    Chad
    Flori-Bama
    Thank you.
  4. Apr 27, 2017 at 9:59 AM
    flyboy718
    flyboy718 Well-Known Member
    Dallas
    05 Prerunner 4 cyl manual 226,000 miles
    I have an 05 PreRunner 4 cyl with the same amount of mileage and my clutch doesn't do that. That doesn't sound like its just an adjustment in the clutch either. $8K is a awful lot for that, I would say $5K max. Mine is running fine and expect to go well past 200K but it is using some oil though.
  5. Apr 27, 2017 at 10:38 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    air in clutch line can do similar
  6. Apr 27, 2017 at 10:38 AM
    80schild
    Chad
    Flori-Bama
    Yeah, it seems like a lot to me too, but I'm just not familiar with what these trucks are worth. NADA says $8k but KBB says $6,500. Not sure which one to believe.
    edit: I called my credit union and they said a retail value of $10,900 and a trade in of $8,300. He told me not to go by what KBB says. I forgot to mention in my OP that it's an access cab.
  7. Apr 27, 2017 at 10:39 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    mine did that and it was the clutch needed replaced...
  8. Apr 27, 2017 at 11:09 AM
    Jigeye
    Jigeye Active Member
    Alaska
    09 2.7L SR5 4x4
    LCE header, secondary air filter removed, AFE pro-dry S, backup camera anytime, blistein 5100s on .75" and General HAD leaf springs, Michelin Defender LTX 165/70/16 on stock rims, Cali Raised stealth mount light bar, leer camper shell, 200k miles mod
    195k miles on my 2.7 and no problems with the engine whatsoever. These engines are pretty bomb proof. Like always, I'd have a mechanic give it a look before you buy, and the price might be a bit high but tacos often sell at rediculus prices, so it's more based on what you are willing to pay than on blue book value.
  9. Apr 27, 2017 at 11:24 AM
    flyboy718
    Dallas
    hmmm didn't know that, so my truck is worth more than I thought. It is running strong as can be though. I just switched over to high mileage oil, changed spark plugs, new air filter, and changed rear diff and manual trans fluids and greased u-joints
