clutch question
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacosuprem, Jun 6, 2010.
  1. Jun 6, 2010 at 7:11 PM
    tacosuprem
    tacosuprem [OP] Well-Known Member
    Florida
    4x4
    Im just wondering at what milage did you change your clutch? I have 209,000 miles and still on the stock clutch.
  2. Jun 6, 2010 at 7:14 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    You obviously know how to drive a manual correctly. Im at 160,000 on what I believe to be the stock clutch. (bought at 146,000)
  3. Jun 6, 2010 at 7:29 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Just changed my clutch yesterday at 173,000 and it was down to the rivits.
  4. Jun 6, 2010 at 9:18 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Change it when it wears out. Test it by parking the truck with the bumper against a concrete wall or barrier or a tree and put it in 5th gear. Let the clutch out slowly. If the clutch is good, the truck should stall. If the clutch is bad or starting to go bad, then the clutch will slip a little bit then the truck will stall, or the truck will keep running.
    Do this test only occasionally though, otherwise it will ruin your clutch. It is very effective though.
  5. Jun 7, 2010 at 4:55 PM
    toycar18
    toycar18 Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
    Or just press the break pedal instead.
  6. Jun 7, 2010 at 5:03 PM
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    Littleton, CO
    2001 DC
    hahaha not all of us have steel plated arb tank bumpers, my plastic one seems to scratch easily :p ill stick with pressing the brake.
  7. Jun 8, 2010 at 5:19 AM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    The test I use for the clutch is to get the truck moving slow ~5 mph in 3rd without it lugging and then floor the accelerator if the truck slowly accelerates you are good. If it revs up quickly the clutch is gone
  8. Jun 8, 2010 at 7:55 AM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    198k on mine so far, had the truck since 49k. no clutch replacement yet.
  9. Jun 8, 2010 at 2:05 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    I replaced mine right about 105k, and it was worn way the hell down
