clutch questions.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Huntn57, Sep 5, 2014.
  1. Sep 5, 2014 at 7:45 PM
    Huntn57
    Huntn57 [OP] Well-Known Member
    Justin
    VA
    1995 Toyota Tacoma
    i com 2300 ham radio. for hunting (170 k miles) list of replacements since 166k miles: 4wd solenoid tailpipe muffer catalitytic conver exhaust manifold
    so all a sudden my clutch is feeling like a sponge and is releasing at the very top. its weird cause its all a sudden. 9 times outta 10 i take off with no gas and i dont burn it up when i shift. so any opinions?
  2. Sep 5, 2014 at 8:21 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    hydraulics need bleeding or replacing is my opinion.
  3. Sep 5, 2014 at 8:22 PM
    TacoMitch93
    TacoMitch93 Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    x2
  4. Sep 6, 2014 at 7:57 AM
    Huntn57
    Justin
    VA
    1995 Toyota Tacoma
    i will try bleeding it. it still shifts good. if i need to replace it imma just weight till it starts slipping
  5. Sep 6, 2014 at 10:00 AM
    tomtom
    The Desert SW
    2012 FJ
    I'm not following. With the symptoms you describe it could be the clutch throw hydraulics (master and slave cylinders). They may need a simple bleeding. They may also be on the verge of failure and need replacing. Not sure what waiting until the clutch starts slipping has to do with replacing the master and/or slave cylinder.
  6. Sep 6, 2014 at 10:53 AM
    Darryle
    Darryle It is just a truck
    Darryle
    Weatherford, Texas
    Probably not the clutch, check the slave cylinder boot, is it wet? Look at the clutch master cylinder boot too, it is probably one or the other. The clutch is most likely fine.
