clutch rattle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by &erson, Aug 10, 2010.
  1. Aug 10, 2010 at 11:20 PM
    &erson
    &erson [OP] Well-Known Member
    Sunshine State
    4x4 SR5
    Wet Okoles, Weathertechs, All-Pro Rear Bumper/Hitch & Sliders
    I've put just over 1k miles on my 4 cyl so far. I've noticed a slight rattle when at a stop & am just curious how normal it is.
    a/c on & in neutral = rattle
    depress clutch or turn a/c off makes it stop
    not very loud, just noticable enough for me to ask
  2. Nov 30, 2011 at 10:15 PM
    Tacoma206
    Tacoma206 Well-Known Member
    Seattle
    2010 Super White 4WD
    I think I have the exact same thing. If the shifter is in neutral and the clutch is out sitting at a light, I hear a rattle. If I touch the shifter tho and slightly adjust it (still in neutral), it goes away. My AC is not on tho, but the fan is. It doesn't do it every day tho. I think we have a similar problem.
  3. Nov 30, 2011 at 10:19 PM
    joes06tacoma
    Joe
    Central Coast, CA
    My work truck (09 2wd 4cyl 5speed) does the same thing. I consider it a quirk, not a problem. There is talk on here about it someplace. Common. Took awhile for me to hear it after listening to everyone else describe it, but it is there.
