Clutch recomendations
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bern, Jul 17, 2016.
  1. Aug 22, 2016 at 5:59 PM
    Bern
    Bern [OP] Well-Known Member
    Western wa.
    Ya that sound like it would be a good set up hows the turbo wat kind how much more power im thinkin bout doin it to mine
  2. Aug 23, 2016 at 6:21 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I'm running a Precision 50 trim. Spools pretty well. I'm running about 7-8psi of boost on it right now. It's typically about 10-12hp per psi of boost you gain for a turbo this size, so I'd guess I'm around 185-200hp at the wheels right now. Seems to be a good amount for my truck with 33's on it. I have a sort-of write up on it here if you're interested in checking it out.
    https://www.tacomaworld.com/threads/boostedkas-turbo-3rz-tacoma.435280/
  3. Aug 29, 2016 at 6:25 PM
    Bern
    Western wa.
    Thank you thats awesome very clean truck was it worth the money because ive really thought about it how was ur mpgs after and whats the rough cost for it all
  4. Aug 29, 2016 at 6:41 PM
    boostedka
    James
    NM
    I ended up spending about $2500 total with all the fabricating and install done myself. That included all the little random things like flanges, clamps, couplers and whatnot. Most bolt on kits run about this much and are non-intercooled. So I figured it worked out pretty well doing this set up for that much and getting it intercooled. That also included buying the piping and muffler to build a cat back exhaust as well. I just need to have a free weekend to get that done in addition to my clutch job as well now. All in all I think is was worth it. I had a S/C'd 3.4 a few years back that I was a little underwhelmed with and spent a little over $3k on including the S/C being used. This setup feels much stronger and efficient than the 3.4 was. That's just my opinion, I don't have any dyno number to back anything yet. My MPG around town are little down (about 2mpg) since doing this setup, but it does take more fuel to make more HP. On the hwy though, it actually gets about 1.5 mpg better. IDK if that is just from the new injectors, fuel filter, and manifold cleaning though. Either way, I got about 21mpg to Salida CO (about 5hrs from me) going 70mph most of the way. That was boosting to pass people on the two lane hwy285 as well. I have been very pleased with it so far. WIth my 4.88's, i'm usually sitting aroung 3000rpm on the freeway so boost is easy to build when needed with this set up. I definitely recommend it if you are looking at forced induction.
  5. Aug 31, 2016 at 6:44 PM
    Bern
    Western wa.
    Right on i noticed that the bolt on kits are not intercooled i didnt like that. That price aint bad at all im think bought 488s as well i got 10.4 goin to montana doin 70 2 weeks ago i cant afford to lose any more milage
  6. Sep 2, 2016 at 6:26 PM
    boostedka
    James
    NM
    Damn that's crazy 10.4!
