Clutch recommendation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 20TACO_OR, Jun 7, 2025.
  1. Jun 7, 2025 at 1:01 PM
    20TACO_OR
    20TACO_OR [OP] New Member
    2020 or man
    Hey guys, new to the forum. Just purchased a 2020 or man with 80K. The original clutch is now spent, and I'm looking for sound advice on clutch upgrades. I love the truck and plan on keeping it till death do us part. I've done some mild research online regarding the centerforce and ACT clutches. Does anyone have experience with these, or recommend other options? Does dual fiction make a difference, a heavier flywheel, should I replace the master cylinder while I'm in there? It's these sorts of things I would appreciate advice on. Thank you!
  2. Jun 7, 2025 at 1:05 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’ve never been forced to replace a clutch in my life, but if I had too, on a modern vehicle, I would go with OEM unless I was building a race truck. Treated properly it should survive the life of the truck.
  3. Jun 7, 2025 at 1:22 PM
    JDSmith
    JDSmith The Overland Shop, VT
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    Mine is pretty heavy and I can feel that it’s nearing the end of its life. These MT clutches take a beating when used off road or towing. The transmission gearing just isn’t low enough.
    If you don’t do a lot of towing or slow crawling off road, I’d definitely go OEM. If you do I’d consider the Centerforce.
  4. Jun 7, 2025 at 1:48 PM
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    Stock truck? Stock clutch.
    69 Jim, b_r_o, Chew and 1 other person like this.
  5. Jun 7, 2025 at 2:05 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I’d go OE unless you have other add ons with significant power increases and drivetrain requirements.
    How the heck did someone smoke a clutch in 80k? Must have beat its butt, rode the pedal at the light, and/or towed a lot (I’ve read backing up in an Tacoma MT with a trailer requires 4lo or significant slipping of the clutch).
    69 Jim and JDSmith like this.
  6. Jun 7, 2025 at 2:17 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    2011 original clutch 168K tow a 17 foot camper every so often, use it as a truck. I will easily get 200K or more out of it.
    69 Jim, Junkhead and Chew like this.
  7. Jun 7, 2025 at 2:26 PM
    gudujarlson
    Minnesota
    I’ve smelt burning clutch smell countless times in my life. I’m not easy on my clutches, especially my dirt bike clutches. But I’ve never been forced to replace one.
    Drive a manual taco over any significant obstacle in 4hi without smoking the clutch is skillz I don’t own
    Junkhead, Chew and doublethebass like this.
  8. Jun 9, 2025 at 6:54 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Reverse is definitely not geared low enough, 2WD LOW mod solves that issue though. I use it a lot because i tow a trailer quite often. I have zero issues with all the other gears, in fact I like how low the 1st gear is.
    Off road? Unless you are in 4HI trying to crawl over obstacles, i dont see how a clutch takes a beating off road in 4LOW.
    I am at 65K miles now, my clutch still feels like it did when the truck was brand new. I dont see why I wont get at least another 100-150K miles from it.
    JDSmith[QUOTED] and shakerhood like this.
  9. Jun 9, 2025 at 8:16 PM
    gudujarlson
    Minnesota
    What do you mean by “heavy”?
    JDSmith[QUOTED] likes this.
  10. Jun 9, 2025 at 8:33 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    The stock clutch is good for the vast majority, and most of the early failures are probably defective. If you are one of the ones abusing it for heavy off-road or running large tires or both, then you would likely benefit from a dual friction or stage 2 center force clutch, and should maybe also consider their heavy flywheel and a regear depending on what you are doing.
    For me, I like the stock clutch because it is adequate for what I do and it is very predictable to drive. I’ve seen people install aftermarket clutches and have shuddering issues, so I tend to err on the side of OEM.
    69 Jim likes this.
  11. Jun 10, 2025 at 5:36 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Going to sound old here, I've been driving standards for over 20 years, never burnt a clutch until my truck. It went out under 40k miles too. I was shocked. Then I learned that an OEM clutch would have cost me about the same as an aftermarket one to replace. So I went aftermarket. Why replace with an OEM that wouldn't last IMO. I went with Centerforce since they are somewhat local to me and I also did the accumulator delete. Now I'm over 80K on that same Centerforce clutch. I'm thinking that was a good decision.
    doublethebass likes this.
  12. Jun 10, 2025 at 5:41 AM
    BLtheP
    Plano, TX
    I get the reasoning, but that is only one data point. The vast majority last much longer than that. It was just an unlucky one. I had 63k on mine when I removed it for the transmission swap and it was still in perfect shape. I bet it was a 200k clutch easily, if not more. But, it’s good the center force is working out.
  13. Jun 10, 2025 at 5:44 AM
    shaggy135
    If you do some more searching, you will find others with similar experiences.
  14. Jun 10, 2025 at 6:19 AM
    BLtheP
    Plano, TX
    I've seen them. Just saying that behavior is not typical and you almost certainly would have gotten normal performance out of the next one. Doesn't really matter, my only point was that just because the first one was a 40k mile clutch doesn't mean all them are.
    69 Jim, shakerhood and Littles like this.
  15. Jun 11, 2025 at 5:12 AM
    JDSmith
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    I still haven’t weighed it. 35’s, dual swing bumper with a 35 spare and water cans, front bumper and 12k winch, sliders, bed rack with storage and 8 gallons of water, decked, cargoglide, tent, roof rack with 8 gallons of water, roam boxes (trips only), Deaver leaf packs (they do add significant weight over stock) and all the misc crap in there.
    Slow speed crawling over significant obstacles, I either burn a little clutch or have to bump to get up and over. I’m always jealous of the autos on the trail, but I love my MT.
    It doesn’t take much to make these trucks “heavy”. I need to re-gear. It’s on my list of things to do, it’s a growing list…
    In a perfect world I’d love to do the RC60 swap, 5.29’s, double t-case and portals. And I probably still wouldn’t think it’s slow enough
  16. Jun 11, 2025 at 5:18 AM
    JDSmith
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    Mine definitely takes some abuse off road. But I do drive slow.
  17. Jun 11, 2025 at 9:39 AM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    2lo mod is amazing for driving a manual gearbox on steep terrain slooowly, and I use it for crawling over rough terrain often (I don't rock crawl) without drama.
    - I like off road drama on youtube videos, but not while I am driving a 4x4 in remote areas.
    2Lo mod essentially lets you use a handful of 'additional gears' - You could argue you get 12 gears in total this way, but there is some overlap.
    I'd love to have a drive in a manual taco with 5.29 gears. It may be a good combination. (Is there a gear ratio comparison table on TW somewhere?? - I'll have to look).
    If it were up to me, I'd make first slightly lower and I'd close the gap between 1st & 2nd a bit. (2nd could be a bit lower for street use). I then would pull the rest of the gears down a bit to match accordingly.
    These ratios would allow for more frequent use of 6th gear. (at the expense of fuel efficiency - likely the reason these are the way they are...). It might imply a slight increased need for shifting - maybe.
  18. Jun 11, 2025 at 9:54 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    RustyGreen, shakerhood and TechDiff1 like this.
  19. Jun 11, 2025 at 10:11 AM
    Gdeyarmond
    Gdeyarmond Well-Known Member
    San Dimas, CA
    2020 TRD OR 4x4 6MT
    Bilstein 6112/5160
    These clutches don't "fail" too often. I'm guessing that at 80k and needing a new clutch, the truck was used for towing and off-roading quite a bit. I took a decent amount of life off my clutch towing (the clutch will shudder occasionally etc.). I coached soccer with a guy who had 205k on the original clutch, but he pretty much just street drove the truck.
    Long story short - I would get an OEM clutch for a 3rd-gen Tacoma and plan on doing so when my clutch gives up.
    Chew likes this.
  20. Jun 11, 2025 at 10:12 AM
    BLtheP
    Plano, TX
    I had 5.29s on an otherwise bone stock truck for a while - I really liked the combo. Fuel efficiency took a slight hit, but I still got 18-19 mpg much of the time, especially if I kept to 70 mph. All the gears being lower was nice. 3,000 rpm at 70 was the 6th gear output, and I was perfectly happy with that. I towed in 5th gear at 65 mph and 3300 rpm.
    I then swapped to the RC60F which paired with the 5.29s was awesome. Even lower low gears, but brought the highway gears back to some level of normalcy.
    With the intention of selling the truck, I swapped the gears back to stock but now have the RC60F with the stock gears. It’s a good combo, although I’m not a huge fan of 6th gear. It is the best fuel economy combo I have achieved so far though and overall it’s a good driving balance.
    JDSmith and OZ TRD[QUOTED] like this.
