Clutch release sensor switch
Discussion in 'New Members' started by Tijean, May 23, 2010.
  1. May 23, 2010 at 4:42 AM
    Tijean
    Tijean [OP] New Member
    N. Ont. Can.
    SR5 4WD
    2.7 L 5 spd 4WD
    First Toyota for me and only complaint I have is needing to press clutch absolutely to the floor to change to 4WD or start. I find it hard to flatten my ankle enough to stab the pedal down. Does anyone know if the sensor switch can handily be repositioned a bit to make it coincide with where the clutch is actually released.
    Frank
  2. May 23, 2010 at 5:03 AM
    jrws6
    jrws6 Well-Known Member
    Western North Carolina
    07, Dodge Ram 35004x4 Cummins Turbo Diesel 6M
    There is a plunger switch at the top of the clutch pedal. just unplug it and connect a small jumper wire and your compliants will no longer exist.
    FYI
    Your truck will start in gear, and shift into 4WD when you turn the knob, so keep these in mind,
  3. May 23, 2010 at 5:08 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    They make a plunger extender for my scion- Maybe you could look at the switch and see if you can add something on top of it?
