Clutch removal help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by armyofsquirrels, Mar 17, 2018.
  1. Mar 18, 2018 at 1:55 PM
    #61
    Muddinfun
    Muddinfun Well-Known Member
    Did you mean you torqued the flywheel bolts to 24 ft lbs? Pretty sure they should be a lot tighter than that.
  2. Mar 18, 2018 at 10:02 PM
    #62
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    From the service manual:
    Flywheel x Crankshaft
    Two stage torque: Torque to value then an additional 90 degrees.
    27 N*m then Turn 90 °
    or
    270 kgf*cm then Turn 90°
    or
    20 ft.*lbf then Turn 90 °
  3. Mar 18, 2018 at 10:25 PM
    #63
    Muddinfun
    Oooooohhhh. That makes more sense. Thanks.
  4. Mar 19, 2018 at 2:00 AM
    #64
    Jimmyh
    SC
    2012 Prerunner SR5
    It is called angular torque or torque to yield and is commonly used on modern engines.
    It can be read about here.
    http://wbtools.com.au/how-to-understand-angular-torque-and-torque-to-yield/
    And as an added note:
    Different to conventional bolts, torque to yield bolts are tightened beyond their elastic range, past their yield point: i.e. past the point from which the bolt material can recover to its original length: and into the plastic phase of the bolt material.
    The bolt is permanently stretched and for this reason should not be reused. The reliability of these bolts once stretched is greatly reduced, if they are reused, they are permanently stretched further a second or third time. It is for this reason, you should never reuse a torque to yield bolt and always follow the manufacturers specifications.
  5. Mar 20, 2018 at 6:21 PM
    #65
    armyofsquirrels
    armyofsquirrels [OP] Embrace the Suck!
    Chip
    Sykesville MD
    2015 V6 6Spd Tacoma DCSB Offroad in Pyrite Mica
    See Build Page.
    I bought new bolts from URD. Pretty much replaced everything. Flywheel, flywheel bolts, pressure plate, pressure plate bolts, clutch plate, TOB with Sleeve, and added a never short throw shifter from URD. It took us a while, but truck is driving amazingly. Will be replacing the Y pipe in the near future as one of the exhaust bolts snapped on use in the flange and had to be drilled out.
    kimo and richiep like this.
  6. Mar 20, 2018 at 6:23 PM
    #66
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    Nope didn't change that out, truck only has a little over 70k on it but the clutch was toast and the TOB was squealing.
    richiep likes this.
  7. Mar 20, 2018 at 8:31 PM
    #67
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
  8. Mar 20, 2018 at 8:37 PM
    #68
    Ackrite
    Ackrite Well-Known Member
    SoCal
    1985 Toyota Pickup 4x4 single cab
  9. Mar 20, 2018 at 8:57 PM
    #69
    SargeBSA
    SargeBSA With self-discipline most anything is possible.
    Cascade Mountains
    2021 SR5 Tundra 4x4
    TRD Offroad Wheels 265/75 18 General Grabber ATX's,
    Thanks for the write up! Getting ready to replace my 2015 clutch also coincidentally at 70,000 miles. @armyofsquirrels
    armyofsquirrels[OP] likes this.
  10. Mar 20, 2018 at 8:58 PM
    #70
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    I hope this isn't a trend lol. I've read a lot of owners seem to have their stock clutches going out on the V6 before 100k
  11. Mar 20, 2018 at 9:00 PM
    #71
    SargeBSA
    Cascade Mountains
    2021 SR5 Tundra 4x4
    Yeah I lack two cylinders though. This is also the clutch I learned to drive manual on and carrying a FWC Eagle full time isn't helping.
  12. Mar 21, 2018 at 3:50 AM
    #72
    richiep
    richiep Well-Known Member
    Rich
    NY
    2006 Tacoma Access 4WD SR5
    Trd s/c 2.85 pully Walbro 255 f/p Urd stage 3 clutch Hurst core shifter Afe cai
    Not a trend!
    Hint, keep your foot off the pedal, & get ur foot off the pedal as soon as possible, meaning don't let the clutch slide out less gas more clutch, practice letting the clutch up with no gas & the clutch will out last the truck.
  13. Mar 21, 2018 at 7:01 AM
    #73
    badger
    badger Well-Known Member
    07 SR5
    There are techniques that make a clutch last. I have over 168K on mine. It is heavy, gets wheeled and used for towing and hauling. I think people have trouble with Tacoma clutches because they have little feel. Bugged the shit out of me when I first got it, but I have many years with clutches, so I learned to drive the taco without it.
    kimo likes this.
  14. Mar 21, 2018 at 7:07 AM
    #74
    kimo
    kimo Well-Known Member
    Knuckle Head
    Kauai
    09 Super White TRD Sport DCLB 4X4! 2017 Silver 4Runner!
    ^^^ Agree 100%
    The TOB seem to be the trend. Chirp Chirp!
  15. Mar 21, 2018 at 8:38 AM
    #75
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Congrats to the OP and those who have performed this repair ..... I've done a lot of repairs of my life but I just HATE exhaust to manifold bolts. If the engine manifold bolts even think I've going to look at it , it will seize forever and refuse to back out. I'm quite capable of removing frozen, rusted, and even broken studs - but I HATE these bolts.
    Many years ago when I was much younger I decided to do my own exhaust. I brought it to a friend who heated it up and pulled and gently replaced the bolts so I could drive it home and perform the work. Then being young and stupid (read I thought I new all the answers) I replaced the bolts with stainless steel. Two weeks later the donut / gasket started leaking. I tried to tighten a 1/2 turn or so and immediately snap both flush (ARRGHG !!). Then I had to cobolt drill out the manifold bolts and made a mess ..... Should have used brass back then. I hate those bolts !!! Rant off !
  16. Mar 21, 2018 at 5:54 PM
    #76
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    Yup I'm gonna be getting the URD Mark II Y pipe here soon than I'll throw the skids up so they can't see the deleted rear cats (will still have the front two) why the hell do we have 4 cats anyway...
  17. Mar 21, 2018 at 7:22 PM
    #77
    Jimmyh
    SC
    2012 Prerunner SR5
    :thumbsup:
    Good job!
  18. Mar 21, 2018 at 8:14 PM
    #78
    Ackrite
    SoCal
    I agree. I'll shoot you over some cash so you can mail me one of the the cats.
