Clutch Replacement Concern
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eppy, Oct 10, 2016.
  1. Oct 10, 2016 at 8:07 AM
    eppy
    eppy [OP] Well-Known Member
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Homer M3 thin lip Satoshi, BAMF Light Bar, BAMF Batwing Tie Downs, Coupe Custom Battery Hold Down, Mattgecko Bed light kit, nj636 hub/wheel bearing set-up,Shorty Antenna, JL Audio & Boston set-up, 4x4 switch light MOD, Icon 2.5 coil overs and rear shocks, All Pro flip kit, Wheelers AAL, OcTaco SS brake lines, Light Racing UCA's and custom 6 speed Ellis Precision Shift knob. Coupe modified short shifter, AISN clutch pack, URD TOB kit, and Sachs flywheel. Mobtown's rocking tailgate skin!
    Gang,
    Not sure if I should be concerned or not, but had a new clutch installed and hearing what sounds like a quick meshing/grinding noise when first starting the truck! I had an AISN clutch kit, new flywheel, slave cylinder and URD TOB kit installed and my mechanic said that its nothing to worry about and should go away because the clutch needs time to seat itself. I consider him pretty knowledgeable because he was a lead mechanic at Toyota, but am a little uneasy because just never heard this in any other clutch I had replaced in the past? Can someone confirm if this normal, or should I be concerned and bring it back??
    Thnx,
    Eppy
  2. Oct 10, 2016 at 10:38 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Meshing/grinding noise when starting the truck means the starter is not properly engaging the teeth on the flywheel. If it's really bad, it can take a tooth right off. I'd have it looked at again.
  3. Oct 10, 2016 at 11:40 AM
    eppy
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Thanks a million and definitely had a feeling it was something bad. Will it need to be completely broken down?
  4. Oct 10, 2016 at 12:01 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    My thoughts as well.
    No, the starter is external and accesses the flywheel through an opening for the starter gear. If it were me I would simply remove the mounting bolts and remount the starter.
  5. Oct 10, 2016 at 12:02 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Not necessarily. I haven't looked at how the starter is mounted on our trucks but it may just need to be reinstalled and possibly shimmed.
  6. Oct 10, 2016 at 12:07 PM
    eppy
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Appreciate the insight fellas and taking her back up tonight to hopefully get squared away.
  7. Oct 10, 2016 at 4:31 PM
    eppy
    Rob
    Maryland
    05 V6 TRD OFFROAD
    I will report back tomorrow and let ya guys know if we get her worked out
  8. Oct 10, 2016 at 7:20 PM
    eppy
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Well that was the issue guys, re-adjusted the starter and she is good to go. Really appreciate the awesome insight. You guys :headbang:
    crashnburn80 likes this.
  9. Oct 10, 2016 at 7:26 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Great, easy fix. :)
