Clutch Replacement DIY Instructions?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jpachard, Dec 14, 2013.
  1. Dec 14, 2013 at 9:27 AM
    jpachard
    jpachard [OP] Well-Known Member
    2006 4WD 4.0L Tacoma 6spd TRD
    Hello All,
    I'm new to this forum and this is my first post! I have a 2006 Tacoma with a manual trans and am faced with the chronic TO bearing squeak. I have ordered a retrofit kit and new clutch from URD (the truck has 100K on it so I figured might as well do the clutch too, while I'm in there).
    I have done a search here and on the web and wasn't able to find a clutch replacement "how to" guide. Specifically, I haven't been able to find a "how to" on removal of the transmission. I've been working on cars for a while and have done several clutch replacements on other vehicles and various race cars so I have all the tools and experience. I just wanted to see if there are any special tools or techniques on the Tacoma.
    Thanks a bunch in advance for any information!
    Cheers, James
  2. Dec 14, 2013 at 9:51 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
  3. Dec 14, 2013 at 10:06 AM
    jpachard
    Hello Gerald, thanks for the prompt response and information. I watched the video and it looks like removing the trans is pretty straightforward. DO you know if I need to remove anything above the trans, be sides the shifter?
    Cheers, James
  4. Dec 14, 2013 at 10:56 AM
    savedone
    Gerald
    Texas
    James I am not sure. Maybe someone else can answer that. Have a Merry Christmas.
  5. Dec 18, 2013 at 8:42 AM
    jpachard
    Thanks again, Merry Christmas to you as well!
    Cheers, James
  6. Dec 18, 2013 at 8:59 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    clutch swap is just like how it is in other cars. Nothing else is on top of the tranny, just a bunch of wires, so just make sure you disconnect all of the harnesses. The only really difficult thing is getting to the top bolts of the tranny. I used a 3' long extension that I approached it toward the rear.
  7. Dec 18, 2013 at 2:49 PM
    jpachard
    3'! that is a long extension! Thanks for letting me know about that.
    Cheers, James
  8. Dec 18, 2013 at 2:57 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    Haha thats how big the tranny is moreso
  9. Jan 6, 2014 at 6:51 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    too bad you dont have a 2.7 or i couldve helped you out. haha
