Clutch replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by BrianPK, Oct 4, 2008.
  1. Oct 4, 2008 at 2:21 PM
    BrianPK
    BrianPK [OP] Offroad Enthusiast
    Modesto, California
    01 TRD 4WD V6 SR5
    CB Radio, 3'' fabtec spacer lift and 3'' body lift flowmaster dual exhaust, deckplate mod, silencer mod, Work in progress pioneer 7900bt stereo with 5X8 infinity speakers all around, and eclipse ex400 amp
    Alright, so i'm sure i'm not the first to ask... but a forum search came up with nothing pertinent.
    my clutch is going out. it slips, and the pedal sometimes needs to be pulled back after shifting, starting etc.
    i called around, even priced it at my work when i was there... all around 700 bucks. Ouch.
    so, of course, being the at-home wanna be mechanic i am, i'm wondering if i can save myself the wallet ache by doing it myself...
    it's a 4x4, and i have the FSM... I'm fairly handy, But i've never done a clutch before.
    any tips, tricks, or special information i should have before i start dropping my tranny? the FSM doesn't outline the whole job in one article, so i figured i'd tap into the collective knowledge that is.. TW! :D
    Tools?
    Parts?
    Timeframe?
    thanks!
    tranny is the r150f i believe. i have the 3.4l v6 and the trd package. also, i have a 3in body lift... nice for getting to those top bolts, right?
    jahsonferg likes this.
  2. Oct 4, 2008 at 2:50 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    You have checked the hydraulic side of the clutch no leaks seems strange you need to pull the pedal back sounds hydraulic how many miles?
  3. Oct 4, 2008 at 2:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hey man...send a pm to 350tacozilla.........this guy knows his stuff when it comes to transmissions.:)
  4. Oct 4, 2008 at 2:53 PM
    BrianPK
    Modesto, California
    01 TRD 4WD V6 SR5
    just hit 108... hydrolics are good... plenty of fluid, no leaks..
  5. Oct 4, 2008 at 3:11 PM
    BeefTaco
  6. Oct 5, 2008 at 12:19 PM
    VeeRFour05
    VeeRFour05 Active Member
    I agree with BeefTaco, sounds to me like a bad slave or master since you're saying that you have to pull the pedel back out.
  7. Oct 5, 2008 at 12:37 PM
    wushaw
    wushaw Well-Known Member
    Texas
    08 AC TRD 4x4 6sp
    Isn't there a return spring on the pedal housing?
    If there is then the hydraulic fluid would have nothing to do with returning the pedal.
    Slipping clutch would be time for a replacement.
    You will need 4 jack stands, jack, transmission jack for tranny ( rental) clutch alignment tool all the hand tools neded to remove all the bolts, drive shafts...etc
    It's time consuming but not that hard.
  8. Oct 5, 2008 at 12:58 PM
    BrianPK
    Modesto, California
    01 TRD 4WD V6 SR5
    i don't always have to pull the pedal back out. even when i do, it's usually when i've had the pedal to the floor for a while. it's like an inch or two at best.
    yes, there's a pedal return spring. i'm sure though, that some of the return force is hydraulic.
    is there a surefire way to check either the master or the slave?
    it started slipping a few weeks ago... the pedal thing followed shortly after.
    the tranny is getting warm.. like warmer than usual. i assume that's from the friction of the thing slipping.
  9. Sep 29, 2013 at 6:14 PM
    Von Himmel
    Von Himmel Active Member
    James
    Pendleton
    01 TRD SR5
    Hey I have done mine twice on my 01 Sr5 trd off road. Pretty easy but a few tips: top bolts to the tranny are kinda a pain but undo all the rest and then remove the cross member support from t case, let the tranny are drop down a little and use a few different lengths of socket extensions and get the top bolts from inside the cab. The get the pilot bearing out pack little wet pieces of paper behind the bearing and use a bolt or socket and hammer it into the middle of the bearing and it will pop out in a few minutes. Aside from that it is pretty easy. Just got done with mine a few minutes ago.
  10. May 5, 2014 at 12:18 PM
    TacomaKTMSkidoo
    TacomaKTMSkidoo Member
    Nova Scotia
    08 Tacoma SR5 TRD Offroad
    Grill Lights Tires Rims
    When I drop the transmission do I have to un hook the gear shifter and thes other cables coming from the tranny?
  11. May 5, 2014 at 12:29 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Yes remove gear shifters. They take just a minute to remove.
  12. May 5, 2014 at 2:38 PM
    Huntn57
    Huntn57 Well-Known Member
    Justin
    VA
    1995 Toyota Tacoma
    i com 2300 ham radio. for hunting (170 k miles) list of replacements since 166k miles: 4wd solenoid tailpipe muffer catalitytic conver exhaust manifold
    it should last more than 108,000 miles. my cousins truck 226,000 same clutch and alot of mtn miles
  13. May 5, 2014 at 2:47 PM
    mustangstephen
    mustangstephen raise hell, drink beer
    Stephen
    by da creek
    02 Tacoma TRD
    Homebrew bumpers and sliders, 5100s & Eibachs up front and mutt leaf pack out back, 285s & Wheelers type B, sway bar deleted. Wife's ride: 01 4Runner 4wd sport. Stock with exception of TRD taco coils, and shift kit.
    My factory clutch lasted about 120k. Word of advice don't go cheap. I just replaced the clutch because my throwout bearing went out after about 50k miles. I'd go marlin or factory Toyota for replacement. Might want to plan on resurfacing the flywheel. I didn't the first time and had a chatter when I shifted at higher rpms.
    I was able to get the top bolts out first before I did all the other bolts with the transmission still sitting on the cross member. Just need a 1/2" universal joint and a few extensions. The rest is pretty straight forward, unplug all the wiring connections, take shifters out, drive shafts, cross member, starter, dust shield, slave cylinder (not in that order) and pull back. I borrowed the cheap HF tranny jack from someone and it worked fine after I put on an extra ratchet strap. Only other special tool I can think of is another set of hands when you pull and stab it. It's a pretty big chore by yourself.
  14. May 5, 2014 at 3:38 PM
    TacomaKTMSkidoo
    Nova Scotia
    Ok thanks I try that.
  15. May 5, 2014 at 4:24 PM
    TacomaKTMSkidoo
    Nova Scotia
    Do I have to disconnect the hydraulics from the clutch release cylinder, because then i'd get air in the hydraulics and, and, and.but I don't see a way to unhook the cylinder otherwise?
  16. May 5, 2014 at 8:52 PM
    2000GTacoma
    Snow Hill NC
    Unbolt the slave cylinder from the transmission along with the brackets that hold the hydraulic lines.
  17. May 6, 2014 at 10:53 AM
    Indy
    Indy Master of all I survey.
    Pack the center with grease and tap a bolt in, rinse and repeat. Every time you tap the bolt the bearing will slide forward a bit. Easy peasy.
    Getting the clutch to align with everything else during assembly took a a few hours though. It was a bigger pain in the ass than it should have been.
  18. May 7, 2014 at 7:53 AM
    Inverno4
    Inverno4 Well-Known Member
    Baltimore, MD
    04 SR5 4x4 TRD Xtra Cab
    My buddy and I did mine at about 125k miles a few years back. Pilot bearing was shot so we did the whole thing. I bought a mid-level brand replacement and it has lasted 60k miles so far without issue. Its all about your driving habits in my opinion.
    The main things I learned is, rent a tranny jack no questions asked. Removing the transmission wasn't bad without on but trying to get it back in was next to impossible especially with the extra weight of the transfer case on 4wd. Second, label your removed nuts and bolts. It makes things much easier when putting it back together. Lastly, take your time putting it back together. We accidentally tore an A/F sensor wire when re-attaching the transmission. That added extra cost to replace.
  19. May 7, 2014 at 8:17 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I did my clutch by myself in a day. I used some extremely tall jack stands and a transmission jack. A swivel for your ratchet is handy as hell. Getting to the bolts on top of the transmission and the flywheel cover are the hardest parts.
  20. May 7, 2014 at 9:54 AM
    wee
    wee Well-Known Member
    I may have to replace mine in the 1999....The first Toyota I had was a 1980 4X4 and I dropped the transmission in it so many times I could take it out and have it back in in less that 2 hours.....No transmission jack, I ran a 4 by 4 thru the doors and lowered it with a come along. Bad transmission rebuild is why I dropped it so many times. I never did get the problem of it popping out of 1st going down hill fixed.
    I replaced the clutch in my 1988 much the same way.
    I might look into getting a transmission jack this time, I'm not as young as I was back then.
    Brian
