Clutch Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by 857975wstbygd, Feb 6, 2020.
  1. Feb 6, 2020 at 6:33 PM
    857975wstbygd
    857975wstbygd [OP] Wv Taco
    Putnam, WV
    2016 White TRD OR
    Stock
    My 96 with almost 200k miles is on its original clutch and it is starting to slip. Was wondering how hard it would be to replace?
    GQ7227 likes this.
  2. Feb 6, 2020 at 6:37 PM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    Just did mine. It took a night in the shop after work to take it out, and a night in the shop with some help to put it back in. Depending on how dirty stuff is, it’s probably a 8-10 hour job.
  3. Feb 6, 2020 at 6:38 PM
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
    What are you replacing it with?
  4. Feb 6, 2020 at 6:38 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    2wd or 4wd?
    5 lug or 6?
    There's prob. a pretty good write up if you decide to.
    It's easier than a FWD. Get it off the ground as high as you can. 2 foot would be great.
  5. Feb 6, 2020 at 6:47 PM
    ToolPac
    ToolPac Well-Known Member
    Show Low, AZ
    2018 TRD Pro, 1998 TRD
    2 feet measured from where? If you're saying the tires should be that far off the ground then he better have some kind of high lift transmission jack. Because mine doesn't reach much higher than that.
    OP: The answer really depends on your skill level and access to the necessary tools. But it'll be a lot harder than paying someone $800 to do it for you and a lot easier than you think if you have the tools and the time.
  6. Feb 7, 2020 at 8:45 AM
    AviateGW
    AviateGW Well-Known Member
    Glenn
    Atlanta area
    Black '99 3.4 SR5 4x4. OME/Dakar
    16x8 KONIG Countersteer Offroads from FN, OME/881s in front, OME shocks/Dakar leafs in back. K&N CAI, and last, but not least, TRD Shift knob.
    I did mine about 5 years ago at ~200k. I took my time, and, had another car to drive while I worked on it. I'm certainly not a trained tech, but I was able to get the job done with help from this forum and others. Working slowly, I took a week of working nights and a solid weekend with no help other than to bleed the clutch.
    You will need access to a transmission jack. Some have done it with a regular floor jack, but that would make the job much harder. I did get my flywheel turned at a local machine shop, and, I replaced my slave cylinder while I was at it.
    cruxofthebisquit likes this.
  7. Feb 7, 2020 at 9:33 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Yes, doing everything is much more likely the new one will last as long as the old one or maybe as long as the truck itself.
    2' (prob. more like 1 1/2') under the tires so you can sit up underneath. If you're young enough to not get dizzy rolling around under there, power to you. I have to be straight up. I also don't like things falling on my head. It's easy to adjust a jack to work at a higher height.
    I did just have a bud do a cutch on his '04. Those dowels on the engine/trans mating surface were surprisingly tight. Never have seen such a bond there and I've prob. pulled 100 combo's apart. They can really seize up and make you think there has to be another bolt hidden somewhere.
    just something to watch for.
  8. Feb 7, 2020 at 9:40 AM
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    my 1995 4x4 W59 I can take out in about 25 min. They are really easy to do. Then again I have done many before that.
    It is really easy but I would suggest separating the xfer case from trans before removing. and when installing be very careful not to screw up the seal.
  9. Feb 8, 2020 at 2:05 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    OP not saying just where the truck lives that can also play into the job .
    Who might have worked on the truck before can as well nothing like using SAE sockets that are close enough.
    We all have our own tricks picked up over the years .
    It can be done alone but I would not want anyone to try that the first time
