Clutch Replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Inferno2016trd, Feb 24, 2023.
  1. Feb 24, 2023 at 8:21 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    It took me a while to find a combo that didn’t have bad acceleration and decel vibrations, but im super happy with it now.
    That is a sub 30 minute clutch job by the looks of it! I am clearly working on the wrong stuff lol
    tonered[QUOTED] likes this.
  2. Feb 24, 2023 at 8:22 AM
    willie2
    willie2 Well-Known Member
    Nova Scotia Canada
    4 Banger 5 spd
    Yes! Slave cylinder is easy to check. just crawl under truck and pull boot off slave cylinder actuator rod and inspect inside for corrosion. If you catch it in time you may be able to avoid replacing clutch if slave cylinder is indeed the problem.
  3. Feb 24, 2023 at 8:26 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I will follow in your footsteps because just a bit more feel and moving that engage point a bit lower would be perfect.
    Yup! The time is mostly spent just aligning the tabs and teeth on the friction and drive plates. The packs last 50k or so, but I was initially in there a lot getting the quiet clutch mod to work. It preloads the pack a bit so that it doesn't eat the basket.
  4. Feb 24, 2023 at 8:26 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welcome to the forum :hattip:
    110,000 km/68,000 miles is very short life for a clutch.
    That "weird revs on the highway" is the clutch slipping - deadly to the clutch.
    More important than which clutch to buy is why such a short life.
    Are you the original owner, if not do you have any vehicle history?
    Big tires or heavyweight mods?
    Trailer towing?
    Is this your first manual by chance?
    Jesse H, Chew, Junkhead and 1 other person like this.
  5. Feb 24, 2023 at 10:30 AM
    Inferno2016trd
    Inferno2016trd [OP] Active Member
    Vince
    TACOMA 2016 TRD INFERNO
    It was bought off of a lease at around 35,000 kms. Very possible it was abused a little. 33" tires with 17 rims was lifted in the last year and I have added some weight, roof rack and bumper. I use the truck for my work carrying tools for tile installation, cement, etc. Never over loading but I'm sure all of this has helped kill the clutch.
    Not my first manual I have driven more manual than automatic. Jeep TJ, Acura Integra.
    No trailer but bed weight for sure.
    I have considered re gearing but on advice 33" tires with a manual should be fine.
  6. Feb 24, 2023 at 11:43 AM
    Inferno2016trd
    Vince
    So I just stumbled upon a recent thread from the 2nd gen forum and they are having crazy amounts problems with the Clutch Masters throw out bearings. Different kit but same manufacturer.. makes me a little nervous seeing so many people having major issues
  7. Feb 24, 2023 at 12:11 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    They have a completely different TOB and nose shaft.
  8. Feb 24, 2023 at 12:14 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Clutch on my ranger was still fine at 230k km when I sold it.
    Im expecting at least 250k km out of my tacos clutch.
    shakerhood likes this.
  9. Feb 24, 2023 at 12:15 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Driver is the biggest variable IMHO.
    Well, unless your Tacoma is a tow rig.
    shakerhood and FishaRnekEd like this.
  10. Feb 24, 2023 at 12:17 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Woke up on the wrong side of bed today?:)
    Halibut, shakerhood and tonered like this.
  11. Feb 24, 2023 at 1:40 PM
    Inferno2016trd
    Vince
    I thought so as well I've never had a clutch issue before in my life owning 3 different MT vehicles. Hence why I am unfamiliar with replacing them. I've always noticed my truck to be a little weird compared to my TJ honestly. The clutch always seems bogged out while in reverse on any sort of incline. Driveways included not only offroad. I might not be be the best MT driver but I certainly don't abuse my clutch or drive it like a racecar.
    Regardless.. here I am with a truck still under financing and a clutch that seems next to death.
    Clutchmasters seem to be the best and fastest option available here in Ontario.
    Apparently Centerforce have a new option but looks like it's $1000 for the kit and flywheel.
    shakerhood and Junkhead[QUOTED] like this.
  12. Feb 24, 2023 at 1:43 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Same here, never had any clutch issues on my vehicles.
    2nd and 3rd gen Tacomas come with clutch fluid accumulator, I think
    That’s what you are feeling. It slows down the fluid to help inexperienced drivers.
    I would recommend getting rid of it, clutch will feel normal again.
    https://www.tacomaworld.com/threads/mt-accumulator-delete-mod-adm-and-bs-thread.568303/
  13. Feb 24, 2023 at 2:16 PM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    Woke up and realized their truck was missing a pedal.
    Junkhead[QUOTED] likes this.
  14. Feb 24, 2023 at 2:17 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That dood never has any good input or advice. Fits the Ignore list nicely.
  15. Feb 24, 2023 at 2:18 PM
    #35
    02Duck
    You make a great point.
    Junkhead and tonered[QUOTED] like this.
  16. Feb 24, 2023 at 2:19 PM
    #36
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Cheers!
    :hattip:
  17. Feb 24, 2023 at 2:21 PM
    #37
    02Duck
    Since I was younger and more into racing, I've been concerned when upgrading clutches to make them too strong. Had experiences with breaking rear ends and transmissions doing stupid stuff without the clutch to absorb it. That's all I caution about.
  18. Feb 24, 2023 at 2:23 PM
    #38
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    :rofl::rofl::rofl:
  19. Feb 24, 2023 at 2:25 PM
    #39
    RDT415
    RDT415 DUCTACO
    Sonoma County
    23 TRD Pro 6MT / past 04 DCSB 4WD
    Can already hear the rocks in the cement mixer going alongside the desmo valves just looking at that pic :thumbsup:
  20. Feb 24, 2023 at 2:31 PM
    #40
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Hahaha! Mine was worse since it originally came with a steel clutch basket. Had to yell at other folks near the bike at idle, with the full cover on. Now, with the QC mod and fully open, it is just the belts, valves, and exhaust, plus nice jangles when the clutch is disengaged.
    RDT415[QUOTED] likes this.
