Clutch Slip After Dealer Installed TRD Supercharger
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vlodpg, Oct 30, 2016.
  1. Oct 30, 2016 at 8:31 PM
    vlodpg
    vlodpg [OP] Well-Known Member
    Connecticut
    15 Tacoma TRD Off Road 6sp Supercharged
    TRD Supercharger/URD Stage II Clutch
    Link to old thread with similar issues:
    https://www.tacomaworld.com/threads/2nd-gen-6spd-clutch-upgrade-options.398123/#post-11033939
    I had my dealer install my supercharger @ 5,000mi & noticed shortly afterwards when under boost the clutch is slipping to the point it defeats the purpose of having it.
    I have been driving manuals for over 30 years,no towing & mostly highway driving.
    Has anyone successfully had their clutch warranted & if so was it replaced with the same unit or an upgraded unit?
    BTW, I have the 8y 100k Extended Warranty
  2. Oct 30, 2016 at 8:36 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Well, if you haven't added anything else but the SC and it warrantied fully through the dealer, yeah you might be able to get the clutch warrantied. But I would HIGHLY suggest you buy your own upgraded clutch and have them install it during the replcement if they will. The OEM clutch just can't handle Supercharger power. Mine went out in about 6k miles to the point where I couldn't even get in to boost in any gear without it slipping. I thought I just sucked at manual transmissions until I started seeing more and more people like yourself with years of driving manuals reporting the same problem. I'm currently running the URD Stage 3 and love it, but for a more stock feel I'd recommend the URD Stage 2 to most people with probably a resurfaced or new flywheel (I'm running the lightweight from URD, but it's not for everyone).
    The dealer said they would check the boost and RPM records in the ECU and if I'd ever high revved it or showed to much boost (which I would since I have the 2.85 pulley) Toyota would turn down the warranty claim. So I replaced it on my own.
    I've also heard from others that some dealers claim the clutch is a 'wear' item and isn't covered under warranties, so you have to pay for the part, but the labor is free, or something like that.
  3. Oct 30, 2016 at 8:37 PM
    eon_blue
    Azusa, CA
    How many miles on your clutch? The stock clutch wasnt designed to handle the added power and torque of the supercharger, I've killed 2 TOBs in stock clutches with my supercharger already. URD sells Competition Stage 1-3 clutches and there's another company I forget the name of that's also recommended. I don't know if a new clutch will be under your warranty but if you continue to put a stock clutch in, the supercharger will continue to shorten its lifespan.
  4. Oct 30, 2016 at 8:44 PM
    vlodpg
    Connecticut
    16k on the truck now, 100 miles highway driving per day. Does Toyota/TRD have a performance replacement? If so I would think that should be covered.
  5. Oct 30, 2016 at 8:45 PM
    VolcomTacoma
    Jeff
    NorCal
    They do not. Like I said above, Toyota MIGHT replace it under warranty, but it's just going to fail on you again. I'm convinced they didn't over engineer that transmission in any way like they did with the Autos (which are run on the v8 tundras, a gen ago) and any power upgrades go past what it's designed to handle.
  6. Oct 30, 2016 at 8:49 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Clutch is a wear item it won't be covered. Same as a set of brakes.
    Put an upgraded clutch in there.
  7. Oct 30, 2016 at 8:52 PM
    Pigpen
    Dan
    Northwest Montana
    Good info on here. My clutch has been stressed from some of the shit I ask it to do. I don't need a replacement yet, but I'll be looking into URD.
  8. Oct 30, 2016 at 8:55 PM
    VolcomTacoma
    Jeff
    NorCal
    HIGHLY recommend a clutch upgrade to anyone with the 6 speed and an SC. It's not if, its when your clutch starts slipping. Better to think about it now before it starts than deal with it when you can barely drive.
    I heard an easy way to check is drop the clutch in 4th gear at a stop...if your truck doesn't stall, you need a new clutch. Mine failed that test at the trans shop just to show the guy how bad it was lol
  9. Oct 30, 2016 at 8:56 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  10. Oct 30, 2016 at 8:57 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Yeah as greed. Mine chatters really bad in first gear now too. Makes it hard to Offroad lol
  11. Oct 30, 2016 at 9:11 PM
    eon_blue
    Azusa, CA
    I have the dreaded TOB chirp just like I did on my last clutch. This one barely lasted 5k miles before it started again, figure it must be the supercharger. Fortunately this clutch is warrantied through Toyota because they installed it (they warrantied it for 1 year) but I'm going to buy Competition Stage 2 clutch through URD for them to install so I don't have to keep worrying about this.
    To answer your question OP, yes TRD does make clutches but I don't know how they compare to some of the other performance alternatives on the market.
    This one is for first gens but they make them for the 2nd gens too...
    http://www.trdusa.com/parts-detail....s=Performance Drivetrain&subcategories=Clutch
  12. Oct 30, 2016 at 9:13 PM
    eon_blue
    Azusa, CA
    For the price of the TRD clutch you can get a Competition Stage 2 clutch through URD and save some money, I think they run around 500.
  13. Oct 30, 2016 at 11:09 PM
    nine3
    nine3 Well-Known Member
    Seattle, WA
    14 DCSB TRD OR Supercharged MT
    Same problem here. My dealer has been a real jerk about it. I brought it in 4 times and they said they couldn't replicate it. Then they said it was a wear item and with only 12k on it they wouldn't be able to do anything. I can't tow or haul anything heavy with it. I'll be upgrading to a URD before long.
    Here's a video of normal acceleration with slippage on the freeway:
    https://youtu.be/H4bKmMmJcs8
  14. Oct 31, 2016 at 12:18 PM
    Redsyota
    Redsyota Well-Known Member
    Denver
    15' SPORT 6 SPEED ACLB MGM
    Some of the things...
    Mine lasted 10k miles before it was slipping enough to annoy me. Now it's a urd stage 2 with their heavy flywheel and tob and the difference is unreal. Much much better than the oem in feel and holding power. Gadget will hook you up! @Gadget@URD
    Plain Jane Taco likes this.
  15. Nov 7, 2016 at 10:06 AM
    vlodpg
    Connecticut
    Made an appointment to have it looked this Wednesday. Same symptoms as
    nine3 video
  16. Nov 7, 2016 at 10:21 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Anyone know if urd makes the competition clutches for the 4x4s? A sc'd taco is in my near future so im curious as to my options for a good clutch replacement that will last. Thanks in advance
  17. Nov 7, 2016 at 10:23 AM
    eon_blue
    Azusa, CA
    Clutches aren't exclusive to 4x4 or 4x2, any clutch made for your model truck will work. The Competition Stage 2 clutch sold through URD is a popular one for supercharged Tacomas
    BassAckwards[QUOTED] likes this.
  18. Nov 7, 2016 at 10:23 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    DO NOT get the Competition Clutch Stage 2 for the 1GR. Unless you want yo have problems soon there after.
    URD brand, SPEC Clutch Brand, Centerforce,
    But not the Competition clutch. I don't feel like going through the history so take my advice if you want.
    12TRDTacoma and BassAckwards like this.
  19. Nov 7, 2016 at 10:26 AM
    BassAckwards
    Any advice on one that you would consider running?
  20. Nov 7, 2016 at 10:32 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Any of the three that I listed. I ran the SPEC clutches. Stage 3+. A chattery bastard until fully broken in, but rated for 550 brake torque, and I was putting out 575 wheel torque, without issue from it.
    Their Stage 2+ is more user friendly for break-in.
    VolcomTacoma can attest for the URD Stage 3. Centerforce has been an industry work horse. Exedy is also good, but they don't have a lot of choiced for the 1GR, as of a while ago.
    BassAckwards likes this.
