Clutch squeak from hell
Discussion in '4 Cylinder' started by hour, Oct 29, 2013.
  1. Oct 29, 2013 at 12:55 AM
    hour
    hour [OP] TL;DR BOSS
    Brandon
    Fort Collins, CO
    '12 Tacoma RC 4x4 (Sold) '14 Ram 1500, '99 4R
    Level 8 Trackers, Hankook Dynapro LT265/75/16, Bilstein 5100's @ 2.5, Wheelers 3-Leaf Progressive w/ factory overload, 5100s all around // Ranch Camper Shell, BHLM, hacked reverse lights, auxiliary reverse lights // Pioneer AVH-P1400DVD, RF Prime Components, BOSS 10" Sub
    Quick background since I typically type too much shit. 2012 Tacoma Reg Cab, 4x4 - 5spd, 4cyl. 23k miles now.
    Clutch squeak started well before 20k but I waited until it was happening almost all the time. Wanted to make sure dealership could replicate, which they did.
    They ordered a new master cylinder and clutch pedal (guy said it had side to side play) - seems about right from what I've read on here as far as parts ordered. There was also mention (on here) of the same parts being used so the problem would likely return again.
    Got the truck back, it drove so much better. Not a noise to be heard and pedal felt great. That was on Monday, 10/21/13. Three days later I thought I heard a tiny squeak (not the CREAAAK) when going to work, but it was silent before I even got out of my complex parking lot. The next day, a slight chirp-creak for a few shifts after the truck had sat for ~2 hrs. Tonight, a week after repair, I get out of the grocery store and it's worse than ever before. Very difficult to drive the truck and that noise? No way in hell is the radio going to mask that.
    http://www.youtube.com/watch?v=jBqjAdoND24
    Moral of the story - you may not want to waste your time at the dealership. It seems common that they have to order these parts, so expect two trips. Also expect that it'll come back eventually - and consider that it may come back rather quickly with a vengeance.
  2. Oct 29, 2013 at 1:00 AM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    standard
  3. Oct 29, 2013 at 1:09 AM
    hour
    Brandon
    Fort Collins, CO
    Less than 500 miles after repair? Shit, from brand new with 1 mile on the clock it took til probably somewhere in the neighborhood of 15k to first manifest. Also haven't seen any other videos of it this loud - it's probably twice as loud as it was when I finally took it to them for repair.
    Being under warranty and with <25k on it, I'm not really in the mood to grab my ankles and suck it up / live with it. It's one thing to do that when you're out of warranty... not reasonable with a relatively new truck. I'll let them replace it as many times as they want but if it starts getting ridiculous I'll look in to the lemon laws in my state. More than just a noise, feels like I'm pushing the clutch pedal in to a rusted pipe full of rocks. I can't be gentle on the clutch like this and I'm not looking to burn it up. I could also never sell the truck private party with it sounding and driving like this.
    I'd like to think maybe they borked the installation, but with it driving beautifully and quiet for a few days.. I'm not sure.
  4. Nov 7, 2013 at 8:05 PM
    rodney
    rodney Well-Known Member
    '15 silva sky AC SR5 V6 4x4- Last of the 2nd gen...
    245/75-16 Duratracs & WeatherTech rain deflectors- This one is staying stock...
    it is a simple fix, really. put some grease on a q-tip, and push it into the recesses of the clutch pedal up high, where it contacts the clutch rod.
    i have to do mine once a year, and it is fine for 12k or so, then it slowly creeps back, stuff some grease in there and i am good for a while.
  5. Nov 8, 2013 at 10:36 AM
    jassco
    jassco Well-Known Member
    Boston
    2010 Access Cab 2.7L SR5 5spd, 4x4
    5100 set to .85 w/ rear TSB, 2012 Rear-view Mirror, Grillecraft, Team Trails FJ Wheels, TPMS canister, Rear headrest delete, Rear console delete, Valley Hitch, Frame undercoat, $2.99 Tailgate hose clamp lock, Avid light bar, 4x4 lighted switch ala Biceman.
    Pretty normal on these trucks since 1995. This one is mostly because of plastic not the bushing failing noise on older ones. I used the same lithium spray I use on my gas door hinge. Hooray for plastic parts! A lot of vehicles have quirks. They should not happen, but they do.
    FYI - I did also have a similar noise coming from under the truck that I thought was this pedal. It is very easy to hear in concrete garage or when truck is against a wall. It turns out the shift fork rusts on these and you have to spray where it contacts the slave. I do it each oil change and have not had the noise come back. I use the same lithium spray as on the pedal.
  6. Nov 8, 2013 at 11:14 AM
    camojared
    camojared Well-Known Member
    Jared
    SE Ohio
    07 4x4 SR5 2.7L 5spd
    Sounds just like mine!!
  7. Nov 8, 2013 at 4:50 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Mine changes with the weather. Sometimes the inside components make noise, sometimes it's the shift fork. I know when it's going to rain soon because about a day before it does everyone outside the truck gets to hear SCREEEEEEE when the clutch gets pushed down. If it's going to be sunny, there's a click with maybe some minor audible squeak. If it's raining, she's quiet.
    I've unbolted the slave cylinder twice and tried both lithium and moly on the ball; unfortunately, the thing is completely exposed to the world and no matter what you put on there it just collects dirt and squeaks anyways.
    To make the OP feel a little better... creak baby creak!
    http://youtu.be/vs0NP_p_3hU
  8. Nov 8, 2013 at 4:52 PM
    ToyotaKTMracing
    ToyotaKTMracing The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    Sounds like a deer bleat. lol
  9. Nov 8, 2013 at 4:55 PM
    iroh
    michigander
    tonneau
    You know I didn't put 2 and 2 together until you said this..... LOL it really does! Sorry OP, leave your windows up or you'll be dodging horny bucks.
  10. Nov 8, 2013 at 7:13 PM
    jassco
    Boston
    I think I will put a large gob of grease where the slave meets the fork area and wrap the area in some silicone rescue tape. It should not hold much moisture and should double the time between greasings.
  11. Nov 9, 2013 at 4:51 AM
    rodney
    or you can grease the pedal to rod junction like i mentioned and solve it... :p
  12. Mar 10, 2014 at 7:53 PM
    jsnee2013
    jsnee2013 Member
    2014 Tacoma 4X4
  13. Mar 11, 2014 at 7:10 PM
    mrbadwrench
    mrbadwrench Well-Known Member
    Cleveland Ohio area
    2014 GMC Sierra 4x4, 1988 Mitsubishi J53
    Wd40 sprayed up in there everywhere (couldn't see shit) solved mine for about 4 months. Then it came back so I resprayed. Fixed again. I just keep lubing it.
