Clutch squeak Linear Spring swap (TW how to)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rucas, May 28, 2011.
  1. May 28, 2011 at 8:30 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    I found a lot of threads asking about how to fix the 1st gen squeaky clutch spring.
    But I could only find the "how to's" on other forums, so I thought I would make one for TW.
    -This fix only took about 20 minutes, and the hardest part was positioning my body right so I could get up in there.
    Very simple fix requires:
    -Linear spring about 5" x 7/16" and about .047 wire thickness
    (I found one at ace 4 1/2" x 15/32" and .014 wire thickness)
    -screwdriver
    1st: I took the screw driver and dislodged one end of the origional spring. After that I just pulled the whole spring out.
    2nd: One end of the spring will attach to a welded tab where the arrow in this picture is pointing to. And the other end will attach to the circled part on the clutch pedal.
    :D enjoy
    (sorry if the pictures aren't as descriptive as they can be, it was pretty tight down there, but hopefully anyone gets the idea)
    supralee and krustytaco like this.
  2. May 28, 2011 at 8:33 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    QMEDJoe likes this.
  3. May 28, 2011 at 11:41 PM
    newskooler
    newskooler Well-Known Member
    Nick
    Mount Shasta, Ca
    1997 ext cab base, 2012 Base Access cab, 2018 trd OR
    Mall Crawler
    Is that a number #70 spring from the hardware store? Thats what I used It gave me a soft clutch feel.
  4. May 29, 2011 at 8:06 AM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    No I couldn't find the #70 spring from true value hardware.
    the one i used is 4.5 inches long and has .041 wire thickness. I honestly cant feel a difference.
  5. Jun 16, 2011 at 7:51 AM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    like a dream still
  6. Jun 16, 2011 at 4:58 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    Looks alright.
    That little play probablly wont affect the clutch mechanics.
    As long as it returns correctly, you should be good.
  7. Jun 17, 2011 at 1:10 AM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    okay, well if you think that the spring isnt getting the tension then you probabll need a shorter spring.
    If your worried that it will slip off, theres a problem. On mine theres plenty of tension on both ends, that I cant imagine it comming loose.
  8. Mar 4, 2012 at 10:40 AM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    same!
    Im thinking of trying different springs so see if I like a lighter pressure spring.
  9. Mar 4, 2012 at 11:20 AM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    strange. I never tried that.
  10. Apr 2, 2012 at 5:33 PM
    YotaKid62
    YotaKid62 Dirty mall crawler
    Forrest
    North Dakota
    00 Tacoma TRD Sr5 5 speed
    Grey Wire Locker Mod, 3" coil spacers & custom leaf packs, 2" BL, Skyjacker rear nitro shocks, Monroe front gas shocks; 15" eclipse sub & 1400 watt visonik amp with Kenwood stereo, Billet Petals, Black Aries series Grille guard, ebay baja lights (unsure of brand)
    I did this earlier...funny toyota wouldn't just do that to begin with instead of that stupid plastic bushing. I got a different spring but I like a firmer clutch feel so its all good:thumbsup:
  11. Apr 2, 2012 at 7:08 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    I bought the same spring as the brake pedal uses. In fact, I bought two and keep the extra in the truck.
    jubei and 04Burk like this.
  12. Apr 3, 2012 at 2:35 AM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    How's the clutch feel? Firm or soft? The same?
  13. Apr 3, 2012 at 9:36 AM
    newskooler
    Nick
    Mount Shasta, Ca
    Mall Crawler
    Mine felt almost the same, maybe slightly stiffer. I've got about 12k miles on it without any problems.
  14. Apr 3, 2012 at 6:29 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    It's slightly firmer than stock.
  15. Apr 3, 2012 at 6:33 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    I agree. Its almost like they were going to, but then decided for some reason to do it the other way.
  16. Apr 10, 2012 at 9:17 AM
    YotaKid62
    Forrest
    North Dakota
    Haha, yea but I've been going in for oil changes, since I hate doing them, but i think i'm gonna start doin them myself and save a few $$$
  17. Apr 12, 2012 at 11:28 PM
    Fejurty
    Fejurty Member
    Vancouver
    02 Ext Cab TRD
    This is a great solution. I found a similar spring in Canada, shortened it a bit and swapped it out in about 15 minutes. It's hard to get your arms in there but after a little contortion you'll figure it out. Pretty much all the rebound comes from the slave cylinder anyway, I"m not sure what the spring really does. Either way, i was surprised how quiet it was after.
    Thanks for the info. Easy mod.
  18. Apr 13, 2012 at 12:19 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    :wink:
  19. May 28, 2012 at 11:07 PM
    Madjik_Man
    Colorado Front Range
    So to be sure...
    I remove that huge ass torsion spring (is that what it's called?) in the first pic and get rid of it entirely. Then replace it with that #70 spring (or brake pedal return spring) by hooking it up to the clutch pedal and the welded tab under the dash.
    And that's it?
    Does it return the pedal so that it makes contact with the cruise control switch?
  20. May 29, 2012 at 8:39 AM
    trmarshall1
    trmarshall1 The Least Interesting Man In The World
    Tim
    San Jose, CA
    02 Tacoma 4x4 TRD Supercharged
    4" Pro-Comp Lift, TRD cat back exhaust, grey wire mod, clutch pedal linear spring mod
    Yes, at least on mine, it solved the non engaging cruise control. No more sticking my foot behind it to pull it up that extra smidgen.:laughing:
    QMEDJoe likes this.
