Clutch squeak near slave cylinder
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pausenot, Feb 28, 2018.
  1. Feb 28, 2018 at 5:04 PM
    pausenot
    pausenot [OP] Member
    2009 Tacoma X Runner
    My new to me 09' X Runner squeaks near the clutch slave cylinder. It is more pronounced when the clutch pedal is returning to position. I loosened the slave cylinder and separated the bellow. Then I sprayed some white lithium grease, careful not to get any on the flywheel. Unfortunately, it still squeaks. Is it even possible to lube up the clutch fork/pivot bearing without having to take the transmission off? There is absolutely no noise coming from the cabin/pedal area.
    Any help is appreciated.
