clutch squeaking??
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blackdawg, Apr 19, 2011.
  1. Apr 19, 2011 at 11:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Hey guys, so i have a weird squeaking sound coming from my truck. It sounds like it would be like a bad idler pulley from the sound its making. However, it goes away when i just rest my foot on the clutch. Like just barely putting weight on it, so little it doesn't feel like i am actually moving the clutch. also goes away under hard acceleration. but is there at idle and is just annoying!
    any ideas??
    i just had all the belts replaced and a new water pump..
  2. Apr 20, 2011 at 5:14 PM
    sgeezy
    sgeezy Active Member
    Shelton
    PB ARK
    SCRATCH n SNIFF
    2.5" rough country lift, Billy 5100's up front, 31X10.50x15 BFG KM2 tires, 15x7 Black Crager 397 series soft 8 wheels. One 15" kicker L7 Subwoofer in ProBox. 2000 watt volfenhag amp. K&N Cold air intake. And 266K miles
    check your slave drive fluid. if u ride the clutch alot it'll burn that fluid up! uses regular dot 3 brake fluid
  3. Apr 20, 2011 at 6:52 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    I have a similar sound coming from the rear though. Its a rrrch sound kinda like if you would burn rubber starting off. It only happens when i start off from first on a slight slope. Maybe its the leaf spring or maybe my rear diff. ????
  4. Apr 20, 2011 at 7:03 PM
    MaTt98
    MaTt98 Well-Known Member
    Medford Or.
    96 4Runner SR5 V6
    Runner SR5, xeon headlights, 6inch kc spotlights, cb in ashtray mod, roof rack, 2.5 inch lift in front with dodge 1500 coils in the rear and skyjacker shocks
    sounds like the throw out bearing mine did that before i replaced the clutch but i may be wrong lol
  5. Apr 20, 2011 at 11:19 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    +1
    Throwout bearing starts spinning when you press the clutch and it touches the clutch cover fingers.
  6. Apr 20, 2011 at 11:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    drat! i was hoping to not have to replace the clutch yet...course 4 or more people have learned to drive stick on it haha maybe ill just get a new one..
