CLUTCH START CANCEL BUTTON
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bassetdad, Dec 29, 2012.
  1. Dec 29, 2012 at 12:14 PM
    Bassetdad
    Bassetdad [OP] What if God Smoked Cannabis
    Harrison, Ohio
    2001 De-Badged SR5 Access Cab 2.7 / 5m
    Access Tononu Cover AFE Pro-Dry S Drop-in Filter American Mag Wheels Bilstein 5100's Black Billet Grill Clear Taillights Perma-Tech sprayed Kennesaw Mountain Rear Bumper Michelin Tires PIAA Driving Lights PIAA Headlights Piaa Tail Light Bulbs Tinted Windows – 50% Toytech AAL URD Short Shifter Tranny - Mobil 1 Engine - Mobil 1 Custom Three Bike In Bed Rack New Toyota Undercoated Frame Clear LED 3rd Brake Light
    Hi Everybody,
    I own a 2001 5m 4x4 with 145k on a 2.7 engine. Each time I start my engine, I have to push the Clutch Start Cancel button in before starting it. Any thoughts on what I need to do to fix this problem?
    Thanks in advance for all of the positive anwsers
    Rick
    Harrison, Ohio
  2. Dec 29, 2012 at 1:37 PM
    misterdmac
    misterdmac Well-Known Member
    Doostin
    In or around the truck
    '97 2.7L DLX
    There is a button that the clutch pedal arm pushes into its housing, allowing you to crank the engine. All the switch does is take that button out of the circuit. I bet the switch is either bad, you aren't pushing the clutch in enough, or the clutch pedal is missing that button. It's a little skinny black button down near the firewall.
  3. Dec 29, 2012 at 1:40 PM
    austinramsay
    austinramsay Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
    Kind of a cool anti theft mod if you think about it! :p
  4. Dec 29, 2012 at 1:53 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    My previous owner had a little anti-theft mod when i bought my truck. There two wire loom under the dash that clip together to create that circuit. Either it is plugged or unplugged. Take a look under the switch and see if you can find the clip
  5. Dec 30, 2012 at 4:43 PM
    bishard
    bishard Member
    97 4runner 5spd 3rz
    My buddies 99 has done the same thing for the past 2-3 years. Always starts just not with clutch.
  6. Jan 3, 2013 at 8:00 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    I hear that using that clutch start a lot will wear your starter.
  7. Jan 4, 2013 at 8:10 AM
    yota14
    yota14 Well-Known Member
    Nathan
    Concord, North Carolina
    1996.5 Tacoma 4wd 6cyl 5spd
    TRD SuperCharger 6in TrailMaster Diff Drop 3in BLift Flow Master Exhaust Sony Explod Radio Pioneer Speakers Rear & Front 2 JL Audio 10" Subs Apline Amp Toolbox Westin Step Bars Vent Visors
    Only if you try to start it in gear. It will lurch forward. If the clutch is in or it is in neutral than it is perfectly fine.
  8. Jan 16, 2013 at 7:36 PM
    Ronaldo156
    Ronaldo156 Active Member
    Ron
    Washington
    Red LED interior swap, Deck Plate Mod, Magnaflow 18"
    What Misterdmac said. I had the same problem, and found that my pedal was un-adjusted on top of not pushing it in fullly.
  9. May 6, 2015 at 8:20 PM
    Red yota35
    Red yota35 []D [] []V[] []D
    Nathan
    Pismo beach
    01 Tacoma trd 4x4 locker LED conversation
    55w hid hi/low,4 55w hella ralley 3000's, Led inside and under, led lights bar, led tail lights custom, 3in fab tech lifet, front diff drop, stage 2 senterforce clutch,
    please help.
    it is not the starter, wire from starter to battery, battery or flywheel. it will start 99% of the time if i press the clutch cancel button. it happens more often when the truck is driven hard. please view video to hear the sounds it makes. https://youtu.be/zCs98wgbgiA
  10. May 6, 2015 at 8:24 PM
    medic2230
    Murph
    Bama! Roll Tide
    you sure the brushes inside the starter aren't worn down? Has the starter ever been replaced?
  11. May 6, 2015 at 8:27 PM
    Red yota35
    Nathan
    Pismo beach
    YES. i have replaced it with 3 starters. i just kept the 3red new starter in there because i knew that it had to be something els. and it happens intermittent. and what i do not get is when i hit the clutch cancel button it turns right over like normal.
  12. May 6, 2015 at 8:31 PM
    medic2230
    Murph
    Bama! Roll Tide
    Hmmm weird.
  13. May 6, 2015 at 8:37 PM
    Red yota35
    Nathan
    Pismo beach
    yes i have had it like this for over a year because the clutch cancel button Will start it without any problem. And I have taken it to mechanics and they just crashed there head and tell me they don't know. i can feel the starter hitting the fly will and its not spinning it is making the connection just fine but its like the starter dose not have enough power to turn the flywheel.
  14. May 6, 2015 at 8:41 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    But it works fine of you push the button?
  15. May 6, 2015 at 8:42 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Any luck op?
  16. May 6, 2015 at 8:46 PM
    Red yota35
    Nathan
    Pismo beach
    yep it works fine when i push the clutch cancel button. and i know other people have had a similar problem with there trucks not starting because of a button under their clutch paddle but mine actually tries to turn over. I think that there's did not turnover at all.
  17. May 7, 2015 at 1:23 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Since none of my vehicles no longer have these things I wonder if the contacts in the pedal switch are worn just enough to cause slow cranking . Then the adjustment might be off enough to make intermittent contact.
    I need to look at the schematics to see just how the circuit is laid out.
    If it works every time with the button pushed
  18. May 7, 2015 at 1:24 PM
    Red yota35
    Nathan
    Pismo beach
    I will try adjusting it and see if it happens
  19. May 7, 2015 at 6:49 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Wtf :confused: so the truck will turn over normaly when you push the clutch in? But will not start unless you push the clutch cancel button?
  20. May 8, 2015 at 4:45 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Haha, how? The starter is doing the same thing no matter if its started using the button or by depressing the clutch...
