Clutch Start Cancel Issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DingleTower, Nov 18, 2021.
  1. Nov 18, 2021 at 4:24 AM
    DingleTower
    DingleTower [OP] My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    Parked on a snowy hill last night so I decided to use the clutch start cancel for the first time just to get a feel for it.
    Not sure if I did something wrong or not but it didn't get me going. Started in first gear 4hi. The started cranked and the truck moved maybe and inch and the starter bogged down. Tried it again same issue. Started with the clutch instead and no issues.
    Not really concerned about the CSC. Probably won't even need it but wondering if there is an underlying issue?
    I've had one other time, also while parked on a hill, that the truck had trouble starting normally as well. A couple of tries got it going though.
    Truck is about two months old.
  2. Nov 18, 2021 at 4:26 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Clutch start cancel is really for low range.
  3. Nov 18, 2021 at 4:35 AM
    DingleTower
    Manitoba
    Pro MT - Lunar Rock
    After typing it all out I wondered if it's only for 4Lo. I haven't RTFM yet. :rofl:
    whatstcp, Junkhead and SR-71A like this.
  4. Nov 18, 2021 at 4:37 AM
    Jowett
    Brian
    North Adams, MA
    Lol, no worries.
  5. Nov 18, 2021 at 6:42 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Clutch Cancel really isn't intended to move your truck with the starter alone. It is used to allow you to roll-start your vehicle by enabling the ignition circuits so that the spark plugs will fire WITHOUT the clutch being disengaged. If you don't understand what 'roll-start' means, I don't know if I can explain it better.
  6. Nov 18, 2021 at 6:49 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    It’s meant to move your truck with starter alone, but it has to be in 4lo as mentioned above. That’s exactly the purpose of clutch start cancel.
    Let’s say you are stuck on a hill and it’s unsafe to roll back, you can use clutch start cancel to creep yourself up.
  7. Nov 18, 2021 at 7:01 AM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    Exactly this! Can really get you out of a jam, though to be honest I've not been in a situation yet where I needed it on my Taco, I have been in situations in my off-road VW where being able to start (or sometimes just crank) the car in gear to creep over an obstacle (I'm looking at you big scary rock in Moab). I'm not saying that there aren't other ways to accomplish the same thing, but that having a way to crank or start in gear can make a sketchy situation a bit easier.
    Junkhead[QUOTED] likes this.
  8. Nov 18, 2021 at 7:26 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It is limited by the power output and gearing of the starter motor at your current battery output. Yes, you can get the engine to turn over in high range, but that is only likely in a flat area or very slight grade. Hills and high loads where the tires have resistance from snow, rocks, etc., you want to be in low range as noted above.
  9. Nov 18, 2021 at 7:32 AM
    Jowett
    Brian
    North Adams, MA
    FWIW, a 2.0kw starter with a fat battery might move it out nicely in high range. 3rd gen V6 trucks all receive the 1.4kw unit.
    RustyGreen and Junkhead like this.
  10. Nov 18, 2021 at 7:57 AM
    lostMarbles
    lostMarbles A Lost Cause
    Micah
    Alaska
    2021 3.5L 6MT, and 1997 2.7L 5MT
    The wingnut behind the wheel
    Clutch start cancel is not needed for roll starts (and if you can get going fast enough you can even roll start an automatic). Using it for roll starts will not help or hurt, but knowing that it is not needed could help if you ever need to roll start a vehicle that does not have it.
    Anyway, that is not the topic of this thread, and other than turning the truck on without getting in I have not personally every found a situation where I wanted to use it. Perhaps I should play with it just because.
  11. Nov 18, 2021 at 8:08 AM
    DingleTower
    Manitoba
    Pro MT - Lunar Rock
    Sorry for starting this Friday thread a day early.
    Tried it again on the same hill in low and got 'er going with no issues. Turns out I'm a moron. Ha.
    Now that I know it works I'll probably never need it again.
    Kev250R, mtip, bzzr2 and 3 others like this.
  12. Nov 18, 2021 at 10:50 AM
    Ainapo
    Ainapo Well-Known Member
    SW WI
    MT+LB=sport
    We have hill start assist on the MT sports. Do you know if that works in 4 low? (I haven't tried yet)
  13. Nov 18, 2021 at 11:30 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It works in all modes and in Reverse if nose down.
    It would be great to have an Off switch though.
    Ainapo[QUOTED] and Junkhead like this.
  14. Nov 18, 2021 at 1:37 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Yes.
    I really don’t understand why there is no switch for us sport guys. I’m sure it could be done but I have no clue as I suck in electronics.
    tonered[QUOTED] likes this.
  15. Nov 18, 2021 at 1:40 PM
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
    Disable ABS and it stops working.
    Also, I use CSC for when I'm working around the truck and don't want to get in to start it.
    binderline and Junkhead[QUOTED] like this.
  16. Nov 18, 2021 at 1:43 PM
    Stompson
    Stompson Well-Known Member
    VA
    2017 TRD Sport Short Bed MT
    OME Lift > Stage 3 ICON, KDMax Pro Tune Leitner ACS, Decked Box
    Lol....I thought the damn thing was to let me start the truck on cold mornings without climbing in and using the clutch. :notsure:
  17. Nov 18, 2021 at 1:45 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Haha!
    Owners manual is fantastic!
    shakerhood likes this.
  18. Nov 18, 2021 at 1:48 PM
    Stompson
    VA
    True story...but I have too many damn manuals to read at work. I can't imagine reading my truck manual at this point. I'm wingin' it!
    Judging by the replies in this thread, I'm not the only one...
  19. Nov 18, 2021 at 1:59 PM
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    You both are right here. The CSC serves multiple purposes. Using it to move the truck or to pop-start your Tacoma are both possible due to this feature.
  20. Nov 18, 2021 at 2:30 PM
    CT Yankee
    CT
    Mia culpa - I guess it's RTFM.
    My current Taco is an Auto, so knowing this is moot.
    My previous '06 Taco was a manual. Never read the owner's manual on this topic - just assumed it was to permit roll-starting.
    I can see how it could help to get moving in some tricky situations, but I never felt that the starter could easily handle moving the truck. I wouldn't have made it a habit to utilize it for that purpose.
